Hi,
recently I bought a defective Sapphire Radeon 9700 off eBay, that had one of its mosfets cracked off the PCB when trying to remove the heatspreader that is placed above the 3 mosfets on the back of the card.
Well, I knew the partnr. of the mosfet from the seller and had already ordered a replacement-chip from Fairchild semiconductor. Today I had the time and tried to repair it.
The following pics show my progress and how hard it was to get this part back on and wired. I say wired, because it wasn't as easy as to just solder the replacement mosfet in, NO! 2 of the 8 soldering-pads had been destroyed, so I had to think about a new way for the connections and with the help of "w1zzard" (the guy who writes the softmod drivers for radeon cards) and some time spent reading the datasheets, I think I figured it our correctly. At least I hope so.
So here are the pics:
That's how the card looked like before starting the repair work. You can clearly see the missing mosfet and the two empty solder-pads.
Here you can see the fresh soldered on mosfet with 6 of the 8 pins connected.
And the last pic now shows the last two connections finished.
Wish me luck guys! Tomorrow I'll be adding some new heatsinks to the mosfets and then I'll test the card.
Greetz
Ingmar
