+ Reply to Thread
Results 1 to 4 of 4
Thread: P4C800-E rev1.02 and rev2.0 vdimm mods
    Memory Addict eva2000's Avatar
    Aug 2002
    Brisbane, Australia
    0
    Okay my 2nd hand P4C800-E rev2.0 arrived to keep my P4C800-E rev1.02 company
    Gonna send one of these boards away to get them vdimm and droop mod. Question is it possible to mod the bios to allow more vdimm options to be set in bios ?
    i want to be able to have 3.55v vdimm max but that would mean
    2.55 = 3.25
    2.65 = 3.35
    2.75 = 3.45
    2.75 = 3.55
    any chance of having more bios vdimm options to access lower range as well 2.95v, 3.05v and 3.15v ?
    Xtreme Member megahurtz-oc's Avatar
    Dec 2003
    texas
    0
    nope u will have to adjust the pot
    the jedi master Tony's Avatar
    Jun 2002
    Manchester uk/Sunnyvale CA
    0
    Eva all you need to do is wait a while, you will get what you need.
    Got a problem with your OCZ product....?
    Have a look over here
    Tony AKA BigToe
    Tuning PC's for speed...Run whats fast, not what you think is fast
    Aug 2002
    Brisbane, Australia
    0
    ah ha Tony's workin his magic
+ Reply to Thread
