+ Reply to Thread
Results 1 to 22 of 22
Thread: 2.4c @ 3.8 with mach1 on MAX-3
    Registered User ScrillA's Avatar
    Dec 2003
    IL
    0
    Hey guys how is it going. I posted up my system over at the ocforums today so I thought since im over here alot too I might put a link to see what you guys think. The the constructive critisim begin. Later!
    http://www.ocforums.com/showthread.p...hreadid=297853
    2.4c SL6Z3 @ 3812 1.6v 317fsb---Abit IC7-G MAX 3---512 3200 hyperX bh-5 2.8v 2-3-2-6---9800 pro 490/390 vmodded---2x Raptor 36 on RAID 0---1 WD 120 SE caviar---Antec TRUE 550 EPS---Prommie MACH 1 Cooling -20c idle -8 load @die, tec cooled GPU 172w@12v watercooled. Microcool copper heatsink on NorthBridge.
    --------------Benchmarks----------
    3d Mark 2001 -- 22,434---super pi 39 sec.---Pi fast 36 sec.--Prime stable---
    Xtreme Addict Kanavit's Avatar
    Nov 2003
    happy place
    0
    you can only get to 3.8ghz on Mach I? i expected 4.5ghz on vapo.
    --===== proud owner of new razor tarantula gaming keyboard =====--
    Registered User Karnivore's Avatar
    Nov 2003
    0
    LOL, not many 2.4C make it that high The one I used to have was better then average and did 300 stable, or 3.6 air/water, under a Mach1 it did 3714.. It takes a damn good 2.4C to break 4 gigs! Do you realize thats still 300 fsb, even for a 3.0C? Few 3.0+ procs make 4.5, and to expect that from the average 2.4 just because its Sub zero cooled is simply WISHFULL THINKING...
    Scrilla
    Decent clocks there bro, looks like you have an exceptional 2.4 on your hands, Nice OC
    Dec 2003
    IL
    0
    LOL 4.5 with a vapo, ok lets see here 2.4 going to 4.5 if i hit 4.4 that would be a 100% overclock. So if your running a 3.0 with a vapo i wanna see 6ghz.
    Karnivore
    I made it into windows @ 4ghz, but was even stable enough to catch a screenie. I was only using 1.7v too. I may just bump it up to 1.725 or so and get a screenie.
    Xtreme Addict CrashOv3r1De's Avatar
    Sep 2003
    NY
    0
    4.5ghz on a vapo with a 2.8C LOL that is 375 fsb bro will have a hell of a time pulling that off. Will need mach1 cooling on the northbridge and it mostl ikely wont make it
    Xtreme Enthusiast brwmogazos's Avatar
    Dec 2002
    HELLAS
    0
    that would be "only" 321 fsb mate... for a 2.8
    thats not toooo much mine did 313 not stable of course.
    Nov 2003
    0
    I believe it was a typo as 375x12=4500, hence the 2.4C which is the highlight of this post.
    I'm just curious why the hell Kanavit automatically expects 4500 from a 2.4 just because its under a Vapo?
    On a sidenote, my 3.0C does 305 no problem under an unmodded mach I.. Gee, according to Kanavit thinking It should do, what 5 or 6 ghz? Or maybe not since its a Prom
    Dec 2002
    HELLAS
    0
    eheh correct...
    erll my 2.8 is prime stable at arround ~4.2 ghz @ 1.75V and its a 2.8 M0 on a mach 2 GT... i wish i could even get a screen at 4.5ghz lol
    XS Intel News & D²OL enhanced enzoR's Avatar
    Nov 2003
    Netherlands
    0
    cuz he thinks its all the same cores .... and he also think that a low fsb high multiplyer is better than a high fsb and low multiplyer....
    Dec 2003
    IL
    0
    Wow, didnt expect this to happen. LOL! I dunno guys, I was just posting my results and ish. Dunno how things went this direction. Never the less, have fun guys. Later!
    Xtreme Enthusiast Alexandrus's Avatar
    Dec 2002
    0
    3.8GHz is no biggy for a good 2.4C, I've seen a 2.4C L319 doing 3.85GHz on air, stable at 1.55V VCore, but no dual channel, only one stick of RAM was used. Once a second stick was added, the mobo couldn't handle the high FSB. It was a stock out of the box EPoX 4PCA3+ rev. 2.0.
    Nov 2003
    0
    Well I guess were down to definition, my experience with a pretty large number of 2.4C's says 3.8 on air is not a "GOOD" proc, more like exceptional, I would even say rare. And I've never said a 2.4 couldn't hit 4.5, just that to expect 4.5, or even 4.0 from 10 out of 10 2.4's IT JUST ISN"T GOING TO HAPPEN
    And 3.8, is an exceptional 2.4, that is far from a daily occurrence, especially air cooled....
    Dec 2002
    0
    You're quite right, 3.8GHz from a 2.4C is exceptional, I've seen only two or three CPUs doing that, and the L319 was the most stable at lower VCore. The other were both L321 and they worked just fine at default volts at 3.6GHz. Wish I had bought one of them when I had the chance, now it's too late
    Xtreme Mentor
    Oct 2002
    boston,ma
    0
    good clocks
    Abit KN9-SLI
    X2 3800+
    1gb corsair pc5400
    2 evga 7900gt
    200gb maxtor sata
    ocz 520w
    heatware:althes
    ebay althes
    Dec 2002
    0
    Indeed, very good, 3.85GHz at stock volts or at 1.55V is not something you see everyday, especially on air cooling, silent aircooling even, SLK-900U and some Antec 92mm fan, and a totaly unmoded mobo.
    Xtreme Guru IvanAndreevich's Avatar
    Dec 2003
    Vancouver, Canada
    0
    Kanavit
    Sometimes I can't really figure out whether you are serious, or joking...
    i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
    Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60
    Quote Originally Posted by CompGeek
    The US is the only country that doesn't use [nuclear weapons] to terrorize other countries. The US is based on Christian values, unlike any other country in the world. Granted we are straying from our Christian heritage, but we still have a freedom aimed diplomatic stance.
    THE ORIGINAL OC JEDI charlie's Avatar
    Oct 2002
    Field of Battle
    0
    nice...
  18. #18
    Nov 2003
    1
    good job dude. I wish you slapped that cooling on my old chip though....ur not gonna believe this.....
    ON AIR
    Wonder what it would do under your cooling man?
    3770k @ 5ghz 1.35v linx stable
    Asus Maximus V Extreme
    8gb Samsung Green @ 2600mhz 11-11-11-31
    EVGA GTX 680
    Corsair AX850
    XSPC Watercooling
  19. #19
    Feb 2004
    Denmark
    0
    ScrillA.. Please tell me your bios settings..
    I also got a mach1 (R404a), abit max3 ( fully moddet) and a 2.4C but i got som problems when trying to get over 300fsb the its feels like windows is slowing down or someting.. Maybe its the agp/pci lock that doesnt work? ( got a 9800xt and a sata disk)
  20. #20
    Xtreme Addict dpa's Avatar
    Nov 2003
    Oslo, Norway
    0
    boot up @ 295Mhz FSB.. adjust the agp/pci til 74/37 IN WINDOWS...
    then increase the fsb to 315Mhz.. now the "slowdown" is no more.. it disappeared on my asus card.
  21. #21
    XS - Extra Strong lalPOOO's Avatar
    Aug 2003
    Toronto, Canada
    0
    Honestly did you think before posting this 4.5ghz would ONLY take 375mhz fsb on a 2.4c
    3.8ghz is quite nice, although I personally think it comes down to the board when passing 3.4ghz on a 2.4c although a nice chip doesn't hurt
    -Phenom2 x6 1055 @stock
    -8gb ddr3
    -Gigabyte UD3
    -Geforce 7900Gt 755/1863 1.562v vgpu
    -OCZ Powersupply 600w
  22. #22
    Xtreme Member dioSRL's Avatar
    Jun 2003
    Romania
    0
    I have 3851MHz on air. 2.4C L319, single channel generic ram, SLK900+Delta cooling. 4PCA3+ rev. 2.0 with no mod and passive NB cooling. Stable enough for some Pcmark and Sandra benchies. Alexandrus found it for me. Thanks mate Maximum speed it would POST is 4023MHz. I would LOVE some IC7 Hypro modded
    Silentâ„¢ Computing
+ Reply to Thread
