what tools and procedures (by procedures i mean like, cut the block in half, carve out channels - not how you design your block) do some of you guys go about when making your own cpu block?
also, where do you get all of the copper from to make it?
it all depends on the design of the block.
most popular DIY blocks follow the #rotor design, all you need is a drill press and a dremel
get your copper stock from onlinemetals.com
or a local metal supplier
Well I've used the drill press and dremel. Lots of clams/vice's and jbweld.
If you're trying to learn a lot about block making check out the procooling.com forums, they have a ton of info on that.
-Phenom2 x6 1055 @stock
-8gb ddr3
-Gigabyte UD3
-Geforce 7900Gt 755/1863 1.562v vgpu
-OCZ Powersupply 600w
