Hi guys,
I'm getting my parts together. What would you reccomend, the 3 tap fill/bleed system or the T-fitting approach?
I would set them up like this...
T Fitting
3 Tap
Cheers,
Pricey
Hi guys,
T Fitting
3 Tap
Cheers,
Pricey
| Unlocked XP 2600+ | Abit AT7 Max2 | Asus GF4 4400Ti 128Mb | 512Mb PC2700 | 17" Benq LCD | LG GSA-4081B DVD±RW |
euhm ...u put the T fitting in the wrong place in the first diagram ...it will only help if u put it before ur pump.
i wud chose the T fitting root, far more clean than the taps.
but i wud still just put in a reserviour over both the 2 methods
Intel i7 930 @ 4.2Ghz 24/7
Asus Rampage 3 Extreme
Asus Radeon HD 6990
Corsair Dominator GT 6GB
Corsair AX1200, 600T
Intel X25-M 160GB
Dell U3011 30" Monitor
