This is a gpu cascade
It is near compleation and willuse R1150 and R507 with a little propane to help oil return. It uses 2 5000 btu rotary compressors and a CPEV on a butchered baker block..
Looks kinda sideways tho...
Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
Well it has a square case for it it is built on a 5000 btu ac frame I got at lows for 87 dollars. and a 55 dollar compressor..Plus a few other choice items.. It is shorter than a prommie ans it is the same size in bothe directions (Square..)
is this one anything like fuggers gpu cascade?
Asus G60VX : Intel T9600@3.299GHZ : Nvidia GTX260M @ STOCK/ .9v
Beautiful Lookin' Work chilly1,
I hope someday to produce Systems as easy as you!
4930K@5.2GHz/ASUS RIV BE/G-Skill 16GB/4x EVGA GTX 780Ti Classified Kingpin Edition with EK-WB's/4x Rosewill Hercules 1600W PSU's for GPU's/Thermaltake 1200W for MB/Cooling: CPU-Vapo, MB/GPU: A/C Conversion Chiller
Actually it is based on the same design only scaled up this one has 4 times the capacity of Fuggers GPU cascade. This should have 250W capacity at -90COriginally posted by Çhrist0ph
Aaaamazzing!
what evap did you put on it? cpu baker?
In the works... P5wdh | E6600 | G-skill 6400 hz | Ocz Gamextreme 700w | 2x Wd 250 raid-0 | 7600gs until i get my x1950pro
Main Rig: - Ic7-g 2.4c @3.3 1.6v| 2x 256mb corsahair 3500 2-3-3-5 | 9700128mb | Antec430 truepower | mcw478uht cpu @ 10c full load
Server:- Epox 8rda+ 2100 @ 2.4 1.85v | 2x 256 corshair 3200 twinx | msi5200 | TTGI520 | slk800 40c full load soon to be watercooled.....
Wow such nice temperature and such nice size. The most cascades a very big systems, but yourth . U crazy man
And have you installed this system on your video, if yes what temps and oc ?
Duron 800@1120(x140) 2.3v/MSI KT133A Vmod/192MB PC133 CL2/Sapphire Radeon 9550 128MB All Vmods 250/200@533/290
3DMark2003
Evap is a butchered baker block testing tonight on a test system tomorrow...
chilly1
If at all possible, could you give us a diagram(Sketch) of your Cascade System?
It would help us Noobs (At building Cascades) something to go by
250watts @ -90c!
Looks like somones going to try and cool on of them 6800's i hear they put out more heat than a prescott
Final -85 to 90 C.....
Very nice work, Chilly1. And you can stick it in the window, too. I consider that a major advantage.
Looks nice.
Gary and sticking ac units in the fridge *shakes head*.
Hopefully the new owner lives in a cold climate. Just wait until you see what this thing will do when mother nature becomes the first stage, and this unit starts acting like a three stage cascade.Gary and sticking ac units in the fridge *shakes head*.
Oyea it does that temp here in lasvegas outside with a 94F ambient''''
Is that with a 250W load?
I May be able to help with that (Sweden). So u just give me that for free..... OK?Originally posted by Gary Lloyd
//The Farbror....Has bad English and bad cooling...
Then you are living up north, down here it's 25c now .Originally posted by Farbror
Ontopic: Very nice and compact cascade .
Shipping and handling would kill ya.. last quote I got for a 60 lb package was 385 ups....Originally posted by Farbror
wow, nice!!
/me trys to think of some place he could add it to his tripple Vapo machine
I got a window right next to the computer too.
The world`s only triple phase-changer PC in one case.
yes 94 ambient -80C 250Wload.... colder ambient colder temps... room temp of 74 should give a head temp of -90C...at250...Originally posted by Gary Lloyd
That's excellent, Chilly1. Good job.
