+ Reply to Thread
Results 1 to 6 of 6
Thread: Brine?
    Mar 2004
    0
    Brine?
    Has anybody experimented with brine as a solution in their chillers?
    I was talking to a chemical lecturing friend about possible solutions and he suggested it. It can get as low as -21C and should still have excellent specific heat capacity. If needed I guess you could add a small amount of ethanol/methanol to drop the temp a bit further without lossing its favourable properties.
    Any thoughts from people better informed than myself?
    Jan 2004
    0
    wouldnt brine corrode the copper? :S
    Mar 2004
    0
    Hmm to be honest I have no idea, if so I assume a anti-corrosive additive would solve it.
    X.I.P. Gary Lloyd's Avatar
    Jul 2003
    Darby FL, USA
    0
    DaBit tried it. The stuff ate up his solder joints and he had leaks everywhere. You might check out his website. It's a good read.
    http://www.icecoldcomputing.com
    Author - Refrigeration Trouble Shooting Books
    Want to learn more? Click Here
    Mar 2004
    0
    Ah well, thx for the info Gary.
    Jan 2004
    0
    yeh. i never thought about the solder joints **DOH** but over time it would eat through the copper aswell i think. not the best thing to use
    owen
+ Reply to Thread
