Is it just me or is maneuvering the pipe bender around a window ac unit somewhat difficult?
I have a Rigid 456 Tri-Bender and It is giving me some trouble. I am getting ready to just start bending by hand
Practice, practice, practice. BTW, Ridgid is high quality stuff.
You have to pull and rotate at the same time dont let the pipe slip in refrence to the bender.
I had a great deal of trouble with mine as well. I think that's why they call them pipe benders and not pipe straighteners. Once metal is bent it is stretched and therein lays the problem. When you try to force back in to another shape it has a tendency to want to kink.
Lian-Li PC-75B, Asus P5WGD2 WS Pro (BIOS 502), Intel Q6600 G0@ 3.5GHz 1.50V, G.SKILL BHZ, 2048-6400C4,4:3@5-5-5-15-5,EVGA GeForce 8800GTX 768MB, CC-644MHz / MC-1100MHz, HT OMEGA CLARO 7.1, Logitech z-5500 5.1, Enermax 660W SLI, Boot Drive - Raptor X WD1500AHFD 150GB, Two Storage & Backup HD's-WD 320GB SATAII inclosed in ICY Dock Hot swapable HD racks, NEC DVD +/-RW ND-3550A, Lite-on DVD ROM SHOD-16P, 52-in-1 cardreader, Deck Legend-Ice Keyboard, Back to my Logi MX500 @1000Hz
-monitor#1 Dell 2407WFP rev. A04, res. 1920x1200
-monitor#2 TV Vizio GV42L, connected with 30' RapidRun cable, Audio - 30' S/PDIF, Belden/Canare cable-> Marantz AV9000 5.1-> 5X 600w ADCOM monoblocks, Veledyne SPL-1200 Sub, SpecResearch keyboard.
Custom Watercooled->CritiCool PowerPlant PCI Relay Card(modded)->Meanwell S150->Iwaki RD-30-> PA120.3 w/ shroud & Yate Loon D12SL-12 Fans, Nexus fan controller->Storm G5->MCW60
Straightening is a whole nuther ball game.
yeah, I've noticed that. My eheim 1060 was just barely to big to fit in the slim cooler with the evap, so I got another cooler. It is the same length and height, but about 3 times wider, so it will make my bending job easier, but I will have to use a good bit more liquid. I have pretty much given up on the pipe bender being that the pipes seem pretty easy to bend by hand. Hopefully I will have the evap in the cooler tonight.
Btw, my evap was getting down to nearly -30c in the air, so is that the kind of temp I can expect to get when it is submerged?
Out in the air temps tell you absolutely nothing, other than the machine works.
