+ Reply to Thread
Results 1 to 11 of 11
Thread: problem with AN50-R
    Sep 2003
    california,usa
    0
    problem with AN50-R
    seems no matter what i do i cant get my ram to run at system speed
    heres the run down and specs:
    Shuttle AN50-R with cpu and mem vmods
    amd 64 3000+ @2700 10x270
    cosair xms 3500 v 1.2 (bh-?) 512x1
    ok so any fsb above 225 will not run with the ram @3200 i have to set it to pc2700 to get it to boot i know its not the ram ive had both my cosair sticks up to 255 2-2-2-5 @3.2v (i have 2x 512 sticks)also thought it was the ram at first so i bought kingston hyperx pc4000 2x512 and it wouldnt do above 225fsb @pc3200 settings either
    anyone have any ideas?
    need any more info?
    LDT is set at 2
    cooling is stock mach1
    X.I.P. CodeRed's Avatar
    Oct 2002
    Australia
    0
    XMS3500 doesnt work too well with the AN50R. Ive tried 4 sticks and got about the same result that you did.
    Sep 2003
    california,usa
    0
    what about the pc4000 hyperx?
    Oct 2002
    Australia
    0
    never used pc4000 hyperx so I cant say
    Is SATA enabled?
    Xtreme Addict kromosto's Avatar
    Apr 2003
    istanbul turkey
    44
    what volt are you giving to rams maybe it is the problem bh5 always need lots of volts
    When i'm being paid i always do my job through.
    Xtreme Enthusiast Popcicle's Avatar
    Feb 2003
    Miles from Civilization...
    0
    XMS V 1.2 is CH-5. The V1.1 is BH-5.
    To really have any luck with the AN50-R a guy
    needs to run 2 X 256mb of single-bank BH-5.
    This will get you some FSB.
    Try and find some 3200 BH-5 and you'll be in business.
    Pops.
    .... I spent a Fortune on Booze and Women.... the rest I just wasted.
    My Heatware
    Xtreme Addict Ragnarok's Avatar
    Aug 2002
    Melbourne Aus
    0
    change to cas 2.5. corsair will run great @ 1:1 after that..
    the difference between cas2 and cas2.5 is in the order of 2 to 3 Mhz at the most
    Sep 2003
    california,usa
    0
    ok i will answer all
    yes sata is enabled but i have tried it without
    have tried the ram up to 3.6v
    i am currently running thr ram at 2.5-2-2-5 3.2v same results ...have tried very loose timmings ...same result
    Sep 2003
    california,usa
    0
    double checked ...the ram is v1.1
    Xtreme Member Confused_User's Avatar
    Feb 2004
    Bay Area
    0
    All corsiar 3500 xms is BH-5.
    Sep 2003
    california,usa
    0
    what i am saying is that dosent it seem wierd that even the pc4000 wont run at 250 (its rated speed)?
+ Reply to Thread
