Hey,
I just started on my water chiller. So far so good i got a few pics that you guys can look at. Let me know what you think.
Lotec25
Hey,
Lotec25
hey Lotec25 I don't have any knowledge about these chilled cooler things, but so far it looks good. I am guessing the top pic is some sort of compressor. It seems to work on the same principle as a chilled line cooler for kegs. where you coil a bunch of tubing in a cooler and as the beer runs through it it cools it off. Good work man keep us updated.
Antec Server Case, P4 2.0A
VIA PX-266, 512 PC 2100, Ti4200 128 bit,
Custom Water Cooling (ViaAqua 1300, Chevette HC, D-Tek TC-4, 2 Sunon 120mm Fans
Maximus_OC,
Yep that is how it works. I got a few more things to do to it before it is ready. So far so good. Thanks for the replies guys.
Lotec25
AFAIK, that res looks way too big for the evap. Its gonna take ages for that evap to cool down so much liquid. You might want to get a smaller cooler or fill up some space with matter.
Asus G60VX : Intel T9600@3.299GHZ : Nvidia GTX260M @ STOCK/ .9v
whats is it out of (fridge, freezer, fridge/freezer)
also is there any chance of a close up of the evaporator, and some pics of the mess you made getting it out.
does anyone know is it safe to bend the evaporator, sorta folding it in on itself to make it smaller to fit inside a smaller cooler box?
Yea i got some pics . That is the best one i got of the compressor it is not to good of a pic.
It is out of a mini fridge. A person told me that he had the same thing and it got the water down to around -20C. The specs are 1amp and about a can of r134a. It gets cold really fast. And The person i was talking to said he had a cooler that help 8 gallons and his temps were at about -20C. That is alot bigger cooler then mine. And if i need to ill put something in there to take up space. I had a smaller cooler to use and it was way to small. And that one was the best i found for the job. I got some more pics of how i set it up i will post.
Lotec25
and here is one more. I did not take none of the mess i made takeing it out, because it was really not that bad. I just cut the side off the the fridge. Hope you guys enjoy the pics. Ill get started back on it tommorow.
I like that fan you are using for exhaust. Really classy!
20026 01 <-- 9500 NP (on air) CPU TEC Cooled.
With detail settings maxed, full PS and VS support, and highest resolution available, my life runs at 60FPS solid.Originally posted by FUGGER
Just the live video sex chat girls come to mind, not that I know anything about that
LOL. It works i got to get it painted just had to get it set up to make sure it would work. And it does.
Lotec25
Ok,
Well i junked this one. Not really it is sitting in my closet now. I picked up a Windows A/C unit this weekend and almost got it done. Ill attach a few pics.
let me know what yea think. Also i was thinking of geeting rid of the fan and using the one that i had on the other to keep it quieter. Will it work as good or not?
Ok,
I got it done and ready to hook to the MOBO. I just got to change liquid. Just becasue it says Antifreeze does not mean it will not freeze.
Lotec25
