Hey isn't it a general rule that memory causes your comp to freeze when not stable and cpu causes reboot and Blue screen? Just curious.
P4 3.0C SL6WU @3.75GHZ 250X15
Abit IC7-G Max3 bios 1.4
Ati Radeon 9700 pro 391/355
6,225 3Dmark 2003 pro
20,465 3Dmark 2001 pro
2x512 PC4000 Corsair Pro
550 watt Antec True Power
Thermalright SP-94 w/92 mm tornado
no, both can happen. For example, clockgen will make my Barton M "lock when the mHz OC is exceeded. Memory errors usually manifest in reboots in a bench or BSOD.
C
according to my findings, CPU error cause blue screen, chipset error causes freezes, memory error cause blu screens
can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
