http://mbnet.fi/elixir/NV40/
http://www.rage3d.com/board/showthre...eadid=33753143
Look em over...thanks to Rage3dForums for this info.![]()
ep0x 8rda+ / 2400 Mobile Barton @ 2.6ghz / Weapon multi room watercooling project / 2 X 256 Winbond Ch5 :-( / 2 X 60gb Maxtor DP9's in RAID 0 / Powercolor 9800SE->9800Pro / Vantec Nexus /
TTGI 520W PSU / 30 pack BudLite
LOL, this has already been leaked here at Xtremesystems.......
xtreemm got 1st guys![]()
Should've known better...hehOriginally posted by Blaster
any1 noticed it has 2 power cables connected to it ?! the final version will have 2 ?! im gonna endup with 3 psu`s in my cas![]()
CPU:AthlonXP-M 2600+@4500+ (1.8Ghz@2.8Ghz),RAM:512MB (2X256) Corsair PC-3500,PSU:Vantec Stealth 520W,VGA:MSI FX5950Ultra (5900u bios flashed),Monitor:LG Flatron 19" (F900P),Mobo:Abit NF7-S REV 2.0,OS:WinXP PRO SP1,Case:VapoChill Titanium PE,HD:a +400gb mix of hd`s 7.2krpm 8mb cache SATA,CDWR:TEAC CD-W450E DVD-ROM:LiteON LTD163D,3DMark01 http://service.futuremark.com/compare?2k1=6588100,PCMark02 http://service.futuremark.com/compare?pcm=1338123
Thought this thread had died...Originally posted by Athlonest
Anyway, guess it'll serve the purpose to answer your question. You won't need mulitple psu's....my bro is running his vapo on an Antec 550w w/out issue on the 12V rail---I would think the vapo compressor takes a lot more juice than any vid card. I would guess any quality psu from 400w up would serve. I recall reading in the [H]ard review that they used and Enermax 431watter w/ their test bed w/ no issues...albeit it was a fairly barebones setup (components being limited to an hd & an optical drive). I have a feeling more is being made about the 2 connectors than the issue warrants. And even if a psu upgrade is required, the TTGI 520w or the Fortron 530w psu's are fairly inexpensive.
thanx for the input.. my point was theres too many bloody components needing rails.. i got 4 on hds 2 cdroms 1 fan controller dunno what also.. hmm i got only 1 rails left .. my pc-inside looks like a spiders net..
