I decided to ditch the external box when I decided I want a sleek and silent rig. I'm minimizing noise by switching to water on my GPU, turning my intake fans down, changing my out take fan to a stealth and matting my case with dynaflow. I could get great temps if I had a dualie heater core on top and with 2x evercool alu frame fans I'd have plenty of air flow and low noise. They look awesome to
SO:
when I go to the auto store probley tommorow what heatercores should I be looking for in particular? Which auto store should I go to?
What kind of tool do I get to thread the holes for the barbs?
What kind of black spray paint should I use to give it a nice finish?
Next up is the shroud. I want to mount the heatercore ontop of my case with the fans under it to make it look nicer. What should I use to make the shroud? I have limited expirences with most materials tho... How do I secure it to my case? And how would I cut holes for the tubes to run inside?
