Page 1 of 2 12 LastLast
Results 1 to 25 of 44
Thread: Water_Cooler's Chiller
    Dec 2002
    USA, FL
    Talking Water_Cooler's Chiller
    i have been doing some work on my chiller and now its up and running w/o load
    pics
    frosty lol u can see that i touch the res at least i used my hand and not my tongue
    evap and res needs some cleaning
    condensor
    would my condensor lose some of its cooling power if i spary painted it
    9000BTU Rotray compressor
    I am Xtreme
    Aug 2003
    Nice system but can you say FUGLY! Its gigantic.... Try hunting down a smaller more compact condensor and put it behind the compressor with the res right infront. Also, why not submerse the pump?
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
    Dec 2002
    USA, FL
    Yeah is is quite big lol i got kind of lazy when i put it together
    the pump will be summersed its just not in the pic
    lol i need to find my theromoniter
    Dec 2002
    USA, FL
    is this any better
    I need a tube bender lol
    also in the top pic sould my cap tube have frost on it
    I am Xtreme
    Aug 2003
    Looks a bit better
    How are you powering the fans? I need to know how to externally power them for my rad box...
    Dec 2002
    USA, FL
    there runing from a old atx pc psu
    but if u have window ac fans u can hook them up w/ the outlet feeding the compressor power
    also i'm going to move the chiller on to a flat piece of wood so i will have more room
    i still need to try it out w/ some water but i have to set up my res 1st
    Dec 2002
    USA, FL
    i've done some work on the res so here is rev1.1
    Dec 2002
    USA, FL
    I have done even more work on my res
    so here is rev1.2
    1.I sealed the holes on the sides they would leck when i put the hose in so now the hose will come out the top
    2.I remounted the pump
    3.I made the evap removeable just in case
    also in other news i think i'm going to paint my cooler to give it a niceer look(it needs it) and i'm not sure if i should use stright mathanol or mathanol/water
    Nov 2003
    Br!ban3 / Aus / State: St0n3d
    Damn thats an ugly beast :P
    Looking good though, keep the work up.
    Ripping it up on old technology
    i4memory.com
    Dec 2002
    USA, FL
    i fixed my frozen cap tube problem by revaccuming it with a triple evac this time
    now i have some stats
    I used anti freeze and water but i got ice around the evap so i guess i have to go w/ methanol
    but the liquid temp was somewere below -20C my cheap thermoniter only goes to -20C but since the liqiud in the thermoniter droped very fast to -20C i'm going to assume its below -20C
    also is my acumulator suposed to get frosty or am i overcharging it
    my low side was 1 inch
    suction temp was -10C i think the frost made my thermoniter read warmer temps so it may be lower
    hi side was 250 psi
    discharge line was 60C
    lol the cold temps made my poor thermoniter pop
    its not what on the outside that counts its how cold it gets that counts
    Nov 2003
    What is the condensor out of?
    i4memory.com
    Dec 2002
    USA, FL
    i think its made out of copper not to beautiful huh so i think i will paint it soon but i'm still thinking on the color
    note: Has any1 noticed i made a banner for my sig lol
    Apr 2004
    Montreal, Canada
    I could be wrong, probably am, but to me the condensor look as if it was of some rusty steel/iron
    Dec 2002
    USA, FL
    u might be right since i got it from a old frigue and had no idea what it was made of
    but what works works
    lol a few days after brazed on that condensor i got this one pic abelow and it looks nicer and probably would get the job done better but i don't like brazing lol to much work
    but i'm still not sure if there sould be frost on the acumulator or not i'll get a pic of it soon
    X.I.P.
    Jul 2003
    Darby FL, USA
    The tubes in a condenser need to be horizontal. The hot gas goes in the top tube and liquid comes out the bottom tube.
    Author - Refrigeration Trouble Shooting Books
    Want to learn more? Click Here
    I am Xtreme
    Aug 2003
    I think he is just showing it, not using it that way
    That thing is HUGE though... No way in hell would I use it.
    Dec 2002
    USA, FL
    o ok so if i use it i will go lay it down flat
    yep it is huge because its a car ac condensor lol its 14 in wide and 18 in tall
    atlest i reached my goal of -20C
    but i want to know how much colder it is do u guys know any cheap temp reader that would give me a close temp reading to the real temp
  18. #18
    Dec 2002
    USA, FL
    i got new pics
    overview i found out my sys works better when my condensor is laid down thanks for the advice gary
    evap very frosty
    acumulator is it suposed to get like this
    also i closed some gaps in my inslation and now my suction line under the inslation is nice and dry
    i found 1 clue to how cold it is 50:50 antifreeze and water freeze at -29C so now i know that i'm colder than -29C
    sould i just use stright antifreeze or will that be to hard on my pump
    also i think i really like this compressor lol it pulls down fast and it has a little hum to it but its not that bad
    ps: its fun when the evap freezes lol i get to see my compressor pull a 5 inch vaccum lol and then i really see some frost the inslution on the suction line can't keep up when it gets that cold
  19. #19
    Jan 2004
    in those last pics your condenser is wrong (will let someone else try and explain how it should go, i'll probably just confuse you), and its probably time to start insulating things
  20. #20
    Dec 2002
    USA, FL
    i don't think i can insulat anything else
    besides the acumulator but if i did then it wouldn't beable to do its job to make liqiud evaperate before it gets to the compressor
    the condensor seams right the gas enter the top and leaves from the bottom
  21. #21
    X.I.P.
    Jul 2003
    Darby FL, USA
    You should fill the res, covering as much of the evap as possible.
  22. #22
    X.I.P.
    Jul 2003
    Darby FL, USA
    There is nothing wrong with a horizontal condenser as long as it gets good airflow and it isn't fighting gravity.
  23. #23
    X.I.P.
    Jul 2003
    Darby FL, USA
    What is the high side pressure now? What is the air temp in the room?
  24. #24
    Dec 2002
    USA, FL
    the hi side psi is 235 psi and the room temp is 27C
    i'm going to go try again this time with a higher antifreeze and water ratio
    wow after 2 hours of having my sys off there is still frost
  25. #25
    X.I.P.
    Jul 2003
    Darby FL, USA
    Your condenser is working fair, but could be a little better. Do you have it raised off the floor so that air can get under it?
