Results 1 to 11 of 11
Thread: How convinient are chillers?
    Jun 2003
    Im asking because the only thing holding me back from starting up a chiller project is my doubts about the convinience.
    portability is not an issue, as i havent moved my computer in almost a year. but, i do turn it on and off a few times a day. i dont leave it on at night, and if i go somewhere for a few hours, i usually turn my computer off.
    how long does it take for a chiller setup to turn on? is it similar to a prommy or vapo ? or does it take longer to cool the liquid enough. and can i just leave it on 24/7, only turning on the pump when i boot my system?
    Asus G60VX : Intel T9600@3.299GHZ : Nvidia GTX260M @ STOCK/ .9v
    Dec 2002
    USA, FL
    if u use a gooded sized compresor, fine tune the sys, and the main thing with getting it to get cold quick is to use a small res but not to small or your cooler may not beable to cope with load
    with that u might be able to get the water to cold temps in mins
    i'm not sure how long it takes with a Window AC chiller since it wouldn't be as finely tuned but with a small res u might still get quick cooling time
    Jul 2002
    If you set up your system with a well insulated reservoir (and a chiller that will handle your load), it will take about two minutes to cool your block to below freezing after 16 hours of down time.
    Keeper's "Heatware"
    Folding for nerdsforjesus.org
    ASUS M2N32-SLI DELUXE
    AM2 6000
    2X36 Gig Rators O/S
    2X250Gig Storage
    2X 2 Gig Corsair
    2X EVGA 7900 GTO
    Most people are bothered by those passages in Scripture which they cannot understand. The Scripture which troubles me most is the Scripture I do understand.
    -- Mark Twain
    Jun 2003
    but what about running the compressor 24/7? would it raise the electric bill a lot, and How noisy are waterchillers?
    -100C Club Member
    Feb 2004
    australia
    depends on how you want to use your system
    i cool 30 mins (20 litres) and get h20 to 2deg with ice block forming. i have about a 5600btu airconditioner.
    i then use a slight over clock say 11x200 for xp3200 and very little vcore 1.8v and a tec 226w power at 9.23v and i can run this things on internet and playing gerenals online, crunching and not have to turn the airconditioner on again for 4 hours, even when the h20 is around 20deg the cpu is idling below 10 degs.
    i could even not choice to use the thing untill the h2o reches 30deg of what eva and still have around room temperaurtre cpu temps.
    Jul 2002
    Noise can be overcome, you will have a larger electric bill.
    I like my clock up there so, as long as the PC is running so is the chiller. Running it about 10 hours a day costs me an extra $50 a month.
    Keeper's "Heatware"
    AM2 6000
    2X36 Gig Rators O/S
    2X250Gig Storage
    2X 2 Gig Corsair
    2X EVGA 7900 GTO
    -- Mark Twain
    Mar 2004
    Murfreesboro,TN
    Chillers are more convenient than promies in terms of set-up; they can be as large or as small as your imagination wills them to be. A single chiller can cool multiple blocks, a prommie just one… My rock-n-roll friend, Chillers Rock!
    Lian-Li PC-75B, Asus P5WGD2 WS Pro (BIOS 502), Intel Q6600 G0@ 3.5GHz 1.50V, G.SKILL BHZ, 2048-6400C4,4:3@5-5-5-15-5,EVGA GeForce 8800GTX 768MB, CC-644MHz / MC-1100MHz, HT OMEGA CLARO 7.1, Logitech z-5500 5.1, Enermax 660W SLI, Boot Drive - Raptor X WD1500AHFD 150GB, Two Storage & Backup HD's-WD 320GB SATAII inclosed in ICY Dock Hot swapable HD racks, NEC DVD +/-RW ND-3550A, Lite-on DVD ROM SHOD-16P, 52-in-1 cardreader, Deck Legend-Ice Keyboard, Back to my Logi MX500 @1000Hz
    -monitor#1 Dell 2407WFP rev. A04, res. 1920x1200
    -monitor#2 TV Vizio GV42L, connected with 30' RapidRun cable, Audio - 30' S/PDIF, Belden/Canare cable-> Marantz AV9000 5.1-> 5X 600w ADCOM monoblocks, Veledyne SPL-1200 Sub, SpecResearch keyboard.
    Custom Watercooled->CritiCool PowerPlant PCI Relay Card(modded)->Meanwell S150->Iwaki RD-30-> PA120.3 w/ shroud & Yate Loon D12SL-12 Fans, Nexus fan controller->Storm G5->MCW60
    X.I.P.
    Jul 2003
    Darby FL, USA
    The less coolant, the faster the pulldown. You need just enough coolant to feed the blocks and little more. My latest tested evap/res design holds 24 ounces of coolant. It pulls down very quickly.
    My latest chiller has a measured power consumption @115V/60hz of 3.2 amps at startup, quickly reducing to 2.8 amps at lowest temp.
    My chillers are not noisy at all IMO, and can be mounted in a window since that is what they are designed for. When mounted in the window, they are dead silent, because the compressor and fan are outside.
    Also, when the outdoor temp is cool, this gives them a major temperature/performance boost.
    And yes, as small as they are, they are larger than they need to be. I could squeeze a chiller into a prommie case, and could probably autocascade it in there, too. I base my chillers on window A/C units to keep prices down, and more importantly to obtain the window mounting advantage. That's the smallest case size window A/C's come in.
    Author - Refrigeration Trouble Shooting Books
    Want to learn more? Click Here
    Jan 2004
    407, Florida
    hey gary i like to see a auto cascade in an ac case... that would some tight work.
    Core i5 760 | Corsair H70 |Gigabyte H55N USB3 | 2x2gb GSKill Ripjaws 1600mhz C9 |ATI Radeon 4890 1GB | OCZ Vertex 2 120gb | Samsung Spinpoint F4 2TB | Silverstone SG05 450BB
    My Heat
    http://heatware.com/eval.php?id=25800
    X.I.P.
    Jul 2003
    Darby FL, USA
    No problem. Would you like direct die block(s) with that or chiller?
    Jan 2004
    407, Florida
    what ever you feel like doin, how much do you think that would run you with direct die blocks? j/w
    My Heat
