:cursing: i don't see no thermostat
Only 2 lines going into the evapourator......
The compressor shuts down after maybe 20 minutes or so of run time when the whoel evapourator gets frosty....
mine could be found where the controls of the airconditior is located. on the back of the controls there should be a wire that extends and goes to the front of the evaporator.
Well on the front it has a switch could "timer" maybe that could be it?
No, what other switches do you have?
Temperature, Fucntion, Air Exchanger, Timer.....
I foudn another ac unit for 25 bucks which i might buy...
Temperature is the thermostat.
There should be two wires on the back of the thermostat. If you connect them together it should keep running.
Okay will do this weekend.
