+ Reply to Thread
Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 76 to 100 of 137
Thread: Gary builds something
  1. #76
    X.I.P. Gary Lloyd's Avatar
    Jul 2003
    Darby FL, USA
    0
    sounds good gary, lemme know when you are done with this one so I can come take a peak at it myself
    It should be done in the next couple days. I have finished the evap testing. The smaller evap came through with flying colors. It went from 25C down to -54C in about 45 minutes. This thing is really kickin. Just some finishing detail work to do now.
    Author - Refrigeration Trouble Shooting Books
    Want to learn more? Click Here
  2. #77
    Xtreme Addict CrashOv3r1De's Avatar
    Sep 2003
    NY
    0
    Sounds good. Cant wait to see this badboy in action!
  3. #78
    I am Xtreme afireinside's Avatar
    Aug 2003
    Cherry Hill, NJ
    0
    A bit large for me but awesome work Jamalco is gona have some fun
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
  4. #79
    Xtreme X.I.P.
    Aug 2002
    0
    -54C and control settings, can;t ask for more than that !
    Have you considered having a test rig with a waterblock so you can actually fit to a cpu Gary, or are you not interested too much in that side ?
    Regards
    Andy
  5. #80
    Xtreme Enthusiast OCme's Avatar
    Mar 2004
    Murfreesboro,TN
    0
    Outstanding work Gary,
    You have demonstrated your advanced level of knowledge, skill, and ability. I'm sure Jamalico will be pleased.
    Lian-Li PC-75B, Asus P5WGD2 WS Pro (BIOS 502), Intel Q6600 G0@ 3.5GHz 1.50V, G.SKILL BHZ, 2048-6400C4,4:3@5-5-5-15-5,EVGA GeForce 8800GTX 768MB, CC-644MHz / MC-1100MHz, HT OMEGA CLARO 7.1, Logitech z-5500 5.1, Enermax 660W SLI, Boot Drive - Raptor X WD1500AHFD 150GB, Two Storage & Backup HD's-WD 320GB SATAII inclosed in ICY Dock Hot swapable HD racks, NEC DVD +/-RW ND-3550A, Lite-on DVD ROM SHOD-16P, 52-in-1 cardreader, Deck Legend-Ice Keyboard, Back to my Logi MX500 @1000Hz
    -monitor#1 Dell 2407WFP rev. A04, res. 1920x1200
    -monitor#2 TV Vizio GV42L, connected with 30' RapidRun cable, Audio - 30' S/PDIF, Belden/Canare cable-> Marantz AV9000 5.1-> 5X 600w ADCOM monoblocks, Veledyne SPL-1200 Sub, SpecResearch keyboard.
    Custom Watercooled->CritiCool PowerPlant PCI Relay Card(modded)->Meanwell S150->Iwaki RD-30-> PA120.3 w/ shroud & Yate Loon D12SL-12 Fans, Nexus fan controller->Storm G5->MCW60
  6. #81
    Jul 2003
    Darby FL, USA
    0
    Here she is, folks. Chiller #2:
    Minus the front grille:
    And a peek under the hood:
    Ain't she a beauty?
  7. #82
    Jul 2003
    Darby FL, USA
    0
    BTW, she eventually bottomed out at -56C.
    The reservoir holds about 45 ounces.
  8. #83
    Apr 2004
    0
    Good work!
  9. #84
    Xtreme Addict kommando's Avatar
    Nov 2003
    Br!ban3 / Aus / State: St0n3d
    0
    You tweaking these things in the process?
    Ripping it up on old technology
    i4memory.com
  10. #85
    Jul 2003
    Darby FL, USA
    0
    I tweak everything, squeezing every last drop of performance out of it..
  11. #86
    2.4C killer Peen's Avatar
    May 2003
    Vancouver, WA
    0
    What do u think it will hold with 300watt load?
  12. #87
    Nov 2003
    0
    Sell me sell me
    i4memory.com
  13. #88
    Xtreme Enthusiast KennethChong's Avatar
    Jun 2003
    0
    omg, that really is a good idea, ive been wanting to try something thats completely enclosed, very very nice work, how hard was the res fitting?
  14. #89
    Jul 2003
    Darby FL, USA
    0
    Building the evap/res is the most difficult and expensive part. It is completely copper and all brazed.
    I am progressively miniaturizing the evap/res assemblies and will eventually reach a point where the efficiency is unacceptable. Thus far the evaps tested are very efficient, but I have some much smaller designs in the works. When I find the optimum size, I will market the evap/res assemblies for those who want to build their own chillers.
  15. #90
    Aug 2003
    Cherry Hill, NJ
    0
    Where the hell have you been! Welcome back!
  16. #91
    Jun 2003
    0
    Im waiting for them! Once again, very good work. So the res itself is coper? How does that work as far as keeping the coolant cold?
  17. #92
    Jul 2003
    Darby FL, USA
    0
    It adds to the heat exchange. I don't think I want to get into the details. My competitors will just have to buy one and cut it open to see how I did it.
  18. #93
    Jun 2003
    0
    ah, np! good luck selling it, im sure it will go quick. When i get done with what im working on now, i might see about buying one if you have one made, this has me mighty interested.
  19. #94
    Nov 2003
    0
    Gary do you this alot or havn't you done this type of thing in a while?
    i4memory.com
  20. #95
    Jul 2003
    Darby FL, USA
    0
    I have been retired for about a year, and selling my books to supplement my income. Before that, I worked on refrigeration systems for over 35 years. So yes, it has been about a year since I have worked with the tools.
  21. #96
    Xtreme Member JWB's Avatar
    Jan 2004
    WOPR Room
    0
    Seems like you are getting back in the swing of things
    24/7 system
    2.4Ghz Q6600 @ 3.87ghz 430x9,
    Biostar TPower IP45,
    ATI 4870 @ stock,
    4Gb Kingston Hyper-x pc-9600,
    Custom water cooled setup,
    -30C self made waterchiller (not used 24/7),
  22. #97
    Jul 2003
    Darby FL, USA
    0
    Slickthellama, if you want a peek you better hurry. I have three people interested, although none have committed yet.
  23. #98
    Admin runmc's Avatar
    Mar 2003
    North Texas
    14
    Hey Gary,
    I have a power supply,waterblock, over 10 feet of tygon tubing and a pump I can donate to research..
    Maybe we could all pool together and build you a test rig. The only catch to it would be that you would have to put it together.
    What do you think, are you accepting the offer??
    Jesus is the remedy
  24. #99
    Jul 2003
    Darby FL, USA
    0
    Works for me. Thanks, Ron.
  25. #100
    Mar 2003
    North Texas
    14
    Goody Box is in the makins.
    I'll post picture after dinner,
    Don Pablos here I come..
    Jesus is the remedy
+ Reply to Thread
