Results 1 to 15 of 15
Thread: chiller
    -100C Club Member
    Feb 2004
    australia
    chiller
    Ok the other day I finally had a chance to get all the stuff I needed for all the different shops and set my chiller up. With the chilled water first I pump that into the maze4-1 with a 226w tec then into the maze4 gpu. I had a lot of trouble insulating gpu maze4, just that there is so much metal surface area on the back of the block for condensation to form. Once I had finished putting everything back together I only managed to play with the computer for 2hrs so could do limited testing.
    -100C Club Member
    Feb 2004
    australia
    this is a picture of what it looks like
    -100C Club Member
    Feb 2004
    australia
    After leaving the coolent for a day I only have to turn the air conditioner on for 20 mins to get the liquid from 15deg to 0deg with a big block of ice also forming, so once I get the correct liquid this chiller is going to rock, I hope.
    I still need to cut some holes in the lid of the esky and some grooves in the side so that I can put the lid on the esky and seal the unit, i will do this when I get some more time.
    -100C Club Member
    Feb 2004
    australia
    Basically I have 20litres of coolant in an esky. The hydro L30 water pump is sitting on the bottom pumping the h20 out, with the return line dumping the h20 into the top of the esky. At 28 degs room temperature, It took 50mins to cool all of the h2o to 0 degs. The coolent im using isn’t antifreeze, so there is a large block of ice forming around the condenser. I need to get some better antifreeze coolant or method, any suggestions?
    Mar 2004
    Murfreesboro,TN
    One solution you might want to try is the 80/20 Methanol/Prestone-Dexcool combination that many people have good results with.
    -100C Club Member
    Feb 2004
    australia
    is prestone-dexcool a inhibitor or coolant of some sort.
    would i a achive a similar effect buy adding 80% methanol to my mix?
    -100C Club Member
    Feb 2004
    australia
    ok this is the esky
    -100C Club Member
    Feb 2004
    australia
    this is my case
    -100C Club Member
    Feb 2004
    australia
    when I fist leak tested the system I had the blocks just sitting on the table, cpu block connected to nothing, and the gpu block connected to the graphics card. I then chilled the water and pumped it through the system with the peltier running as a heatload. The gpu block formed a puddle of condensation on the bench, wasn’t very happy. So next I attempted to insulate the block with what I had. Heres a pic
Name:	maze4 gpu double sided tape(pg6).jpg
    -100C Club Member
    Feb 2004
    australia
    next I sealed the pcb with conformal coating (non corrosive)
    finally I stuck the enclosed foam onto the block, two layers and rapped the hole thing in gray sticky tape. I had to cut some of the heat sink spikes off and a small section of the insulation (on the underside of Block where the tubing connects to the gpu.
    ) so I could mount the block to the video card correctly, this was a pain in the but.
    -100C Club Member
    Feb 2004
    australia
    and this is the finished graphics card
    -100C Club Member
    Feb 2004
    australia
    the air conditioning unit that I used is cable of removing 1750w per hour and uses 660w of power. Heres a picture of what the air conditioner looked like before I stripped it down.
    at stock speed the with 2deg h2o running and the 226 tec set to 9.23v idel is -13deg
    i can run this this for like 3 to 4 hours before the water reaches room temperature then turn the air conditioner on for half an hour.
    my current everyday usage o/c is 11x200 for an xp3200 and a vcore of 1.8v idle at -8deg's. i use as low as possible temperature on the tec because the difference between 13.5v and 9.23v is no difference really maybe 1 deg.
    Nov 2003
    Br!ban3 / Aus / State: St0n3d
    Looking good, my mate got a nice ac unit and he just wants the radiator for watercooling so im using the compressor
    Ripping it up on old technology
    i4memory.com
    -100C Club Member
    Feb 2004
    australia
    to day i switched to nulon antifreeze and im getting -20deg in 2.5hours
    im getting idle speed if -22C stock and -18C xp3200
    Mar 2004
    Murfreesboro,TN
    It is antifreeze that is red in color and both ethy lene glycol (EG) and propylene glycol (PG) are used as the antifreeze base.
    Lian-Li PC-75B, Asus P5WGD2 WS Pro (BIOS 502), Intel Q6600 G0@ 3.5GHz 1.50V, G.SKILL BHZ, 2048-6400C4,4:3@5-5-5-15-5,EVGA GeForce 8800GTX 768MB, CC-644MHz / MC-1100MHz, HT OMEGA CLARO 7.1, Logitech z-5500 5.1, Enermax 660W SLI, Boot Drive - Raptor X WD1500AHFD 150GB, Two Storage & Backup HD's-WD 320GB SATAII inclosed in ICY Dock Hot swapable HD racks, NEC DVD +/-RW ND-3550A, Lite-on DVD ROM SHOD-16P, 52-in-1 cardreader, Deck Legend-Ice Keyboard, Back to my Logi MX500 @1000Hz
    -monitor#1 Dell 2407WFP rev. A04, res. 1920x1200
    -monitor#2 TV Vizio GV42L, connected with 30' RapidRun cable, Audio - 30' S/PDIF, Belden/Canare cable-> Marantz AV9000 5.1-> 5X 600w ADCOM monoblocks, Veledyne SPL-1200 Sub, SpecResearch keyboard.
    Custom Watercooled->CritiCool PowerPlant PCI Relay Card(modded)->Meanwell S150->Iwaki RD-30-> PA120.3 w/ shroud & Yate Loon D12SL-12 Fans, Nexus fan controller->Storm G5->MCW60
