I know how to do the mod, but I only have a 100ohm fixed resistor available instead of the 680hm as recommended. Will I be okay using the 100 ohm?
I have a range of pots too, from 1K upto 47K, which one would be best to use in combination with the 100ohm (if it's okay to use)?
and finally, 12.8v should be an okay figure shouldn't it?
Thanks in advance guys
PSU is an Antec TC550 btw.
