Initially I'd think a direct phase change system would be ideal since it offers less chance for heat to leak and put the least material between the die and the phase change.
However it does limit the size of the evap, so in so much as the evap is the limiting factor, the chilled liquid approach has an advantage.
I'm really not sure how different the two would really be. Please advise.
