+ Reply to Thread
Results 1 to 17 of 17
Thread: Need help with P4 OCing
    Sep 2002
    Boston, MA
    0
    P4 OCing
    Well I decided to try P4 OCing, as I've been an AMD man a while. Someone offered me a lot of money for XP1600+ and Epox 8K3A and it was enough to get me a 1.8a northwood and Abit BD7-II. Now I started overclocking tonight, and managed to get it to 2.4ghz right out of the box. I'm not familiar with P4 packdate things so this is what the heatspreader says:
    Sl63X Costa Rica
    320 2A053-0789.
    Now my concern is memory scores. With a locked 18x, I managed 140FSB or 2.52ghz @1.6Vcore. With the 3:4 ratio, that would be 374mhz DDR right? I have XMS3200 C2, and would have liked to be able to push it far but is it not gonna happen with this CPU? Also can someone tell me if I got a good packdate and any general help or tips on OCing this thing I'm still a bit new to it.
    Thanks in advance
    Overclocking Guru OPPAINTER's Avatar
    May 2002
    SoCal, USA
    0
    Sorry I can't help help you with Packing dates, I have no clue. You should be able to see what your memory is running with Wcpuid, your probably about right. As far as getting it overclocked higher it's just a matter of good cooling at this point. Your mem will take you as high as your CPU will allow.
    OPP
    Sep 2002
    Boston, MA
    0
    Welll after some burning in I have it running stabely at 2.43ghz with 1.575V. I managed to get it that high with stock voltage but it would fail prime within an hour. Memory is at 180mhz 2-5-2-2 Enhance on @2.6v.
    I'm quite pleased with that especially since I haven't been able to get my TEC on it (only have a Socket A Maze 2-1). Screenies and benchmarks will come soon hopefully
    Xtreme Addict Creative's Avatar
    Jun 2002
    Melbourne, Australia
    0
    I had a 1.8a recently, and it ran at 2.7 in my system for about 3 days before I sold it to a mate. I remember cos I ran it at 150/200 fsb for daily use as a nice round number
    This was at 1.75 volts IIRC
    Prod Code: SL63X
    FPO Code: L207A249
    Version : A78297-003
    Pack Date: 05/13/2002
    Made in Malaysia
    Intel P4 3.2 EE || Asus P4C800-E || Prometia Mach II || 2 x 256Meg HyperX 3500 || Antec TrueControl|| Sapphire Radeon 9800XT || 2x Raptors || Samsung 172T
    OCAU 3DMark Team || 3DMark Compare: 26847 || World of Britney|| PCDB Entry
    "Sundance is weird. The movies are weird. You actually have to think about them when you watch them. " -Britney Spears
    Sep 2002
    Boston, MA
    0
    Creative, with a 130CFM delta blowing past my heatsink and northbridge, the temps were significantly lower and with the VID pin mod I set Vcore to 1.75V (1.71 actual because of BD7-II undervolt) I was able to get 150FSB too. Here are some benchmarks:
    Hopefully as soon as I get my maze 3-1 I can push this thing further and put a bit more voltage through it Is it OK to run say 1.85Vcore in it for a couple hours and still be ok or will it spoil even for a bit of OCing?
    Sep 2002
    Boston, MA
    0
    Here's my latest @DDR406:
    Jun 2002
    0
    I use up to about 1.80-1.85 volts while benchmarking and then tone it off to about 1.70 for everyday use. So far none of my cpus have died, touch wood....but I think my IT7 just bit the dust.
    I cant get it to boot up without saying the FF error code.....ive done everything imaginable but it just wont post....
    Nice scores and OC there bud, get some water cooling onto her and she will be happy...
    Sep 2002
    0
    I also have a SL63X 5/13/02 1.8a and I struggle to get it over 2.41... (I had it at 2451 the other day now it won't prime at 2451 or 2433 ;/)
    This is with the default cooler and core at 1.775v (Which undervolts to 1.71-1.74)
    Cheers,
    Xe0n
    Sep 2002
    Boston, MA
    0
    Been at work for the past couple hours and have come up with:
    Jun 2002
    0
    Bushboy thats a pretty damn nice OC there dood
    I dont have screenies of my 1.8A atm cos on a different machine but Ill post some later today....
    IIRC I could do 2750 @ 1.72 volts or something, that was the MAX i could take here. More volts didnt do anything to her except make her hotter.....
    Sep 2002
    0
    I'd watch out with the 1.85vcore. A few days ago I could prime for hours at 2451mhz. The next day I go to my friends lan, and spend 5 or 6 hours playing with my overclocking, showing it off to my mate and seeing how high I can prime it. Anyways next day I go home and go back down to 1.775v (I usually run it at this, so it stays between 1.71v and 1.74v) and I can no longer prime at 2451, it just won't go 2451 anymore in prime.
    I've learnt my lesson. But best of luck with your overclocks, I don't like being so negative.
    Cheers,
    Xe0n
    Sep 2002
    Boston, MA
    0
    This CPU or RAM just does not want to stop. CPU is reaching 50C+ at times and is becoming less stable, which I'm sure the Maze3 coming on wednesday will fix. At 2.86ghz, or DDR424 I had to lower timings to 2-7-3-3 which is why it's not too much better than the previous benchmark:
    Not bad DDR424 still cas2 at only 2.7Vmem I can tell the CPU can go further as it was about to load windows at 162FSB, 2.9ghz but CPU was too hot to be stable enough.
    And BTW Vcore is not going above 1.8v. When it goes near 1.8 its for a short time too I want this thing to last!
    Sep 2002
    0
    Can you prime at that speed though?
    Cheers,
    Xe0n
    Sep 2002
    Boston, MA
    0
    AT 2.86ghz it failed prime within an hour unfortunately. I was able to run sandra burn-in for CPU and mem and it hadn't failed until I got tired of it and the temps were getting higher than my liking. I think when I watercool it, it should make a difference in stability.
    Xtreme Mentor
    Jun 2002
    PA, USA
    0
    Very nice OC there, Bushboy!
    | 1.6GHz Intel E2140 @ 3.2GHz 24/7 | Abit IP35-E | 4GB Corsair XMS2 PC2-6400 | 512MB XFX Radeon HD4770 | 100% CPU OC & 24hr Prime95 stable | Heatware |
    Sep 2002
    Boston, MA
    0
    Thanks But wait, there's more. I got my maze 3, but only to find my dedicated PSU has mysteriously stopped working so now TECing for now. Anyways with some nice cold water the temps were well below 17C and I've been able to push this CPU even further...I'm quite amazed:
    BTW anyone know what the system temp censor is for the bd7-ii on MBM? I set it to winbond1 I think and it rebooted.
    Memory Addict eva2000's Avatar
    Aug 2002
    Brisbane, Australia
    0
    nice my older pack date
    SL63X
    Malaysia
    Batch: L208A782
    Pack date: 18/5/2002
    P4 1.8A@2627 at 1.825v on P4B533
    Alpha 8942 with 80mm sunon 50cfm fan
    512MB Samsung PC2700@194.5mhz 2.5-3-3
+ Reply to Thread
