Can anyone help me with a TurboPLL for my P4T533-C...
I know allready (talked to Kamu) about the location where i should solder some wires:
yellow wire - R144
red wire - R143
3.3v - R232
ground - C222
but i have for "External PLL" an ICS 952001AF from a ECS P4S5A but i don't know where to connect the wires...
here's the specs of the chip if it can helps.
http://www.icst.com/products/pdf/952001.pdf
he told me:
connect yellow and red wire pin. 2 (ics 95200, output 14.3MHz) and 1.jpg you see
where you connect those wire in motherboard. Is this O.K
