Ok, good idea! Thaks
Old Standby:
DFI LANPARTY nF4 Ultra-D (R.AD0) 623-3 BIOS
AMD Athlon 64 3800+ X2 (CCBWE 0529SPMW)
THERMALRIGHT XP-90 w/Panaflo FBA09A12H-1AZ 90mm (56.8cfm) - AS Ceramique
MSI NX6600GT-TD128E GF 6600 GT PCI-E
WD Raptor 74G Boot, WD 1200JB IDE
NEC ND-3520AW Black
OCZ OCZ600ADJ ATX 600W
ALPS Black 1.44MB 3.5" Internal Floppy Drive Model DF354H121F
Lian Li PC-60USB B2 Silver Aluminum ATX Mid Tower Computer Case
Win XP Pro (32-bit) SP2
I have a senfu stand /tower, .Originally posted by Karnivore
Well you still obviously need to cool the processor and your vid card unless its an antique As for setting up on Anti-static bags, It would be ok unless they are the Silver metallic looking variety. If it is indeed the Silvery metallic bag don't do it, they are conductive and it could possibly cause damage. A soft Static-free cloth, cardboard (shipping box) or most anything else no-conductive works well.
Setting up for testing prior to install isn't a bad idea at all, just take your time, make sure cards are fully seated, nothing around to short anything etc.. Plenty of Xtreme folks around here don't even use cases
Here is a shot of what your probably referring to as a "motherboard mounting rig" This is a Senfu Tech Station, pretty nice setup, unfortunately I believe they have been discontinued by the manufacturer...
Bought if for £40 uk @ www.over-clock.co.uk it's a nice little setup
if you are constantly taking your pc to bits or even if you want to run it
perminently on that it's worth the investment and it's always been fine for anything i needed it to do .
And yes i believe they have stopped manufacturing them but i would not
be surprised if you could track one down somewhere ...
Thanks M4D! I'll be in London next fall. Perhaps I can hunt one down there if they don't ship overseas?
Old Standby:
NEC ND-3520AW Black
No problem.
Have a look here: http://www.neoseeker.com/Hardware/Pr...enfu_DIY_Case/
And here: http://www.senfu.com.tw/layout/default.asp
Hope you know how to read other languages, .
And i have seen the senfu racks at a local computer fair !
But i can't remember which one it was, I think it was in doncaster
at the northern computer markets fair But i can't honestly remember ?
Rest assured you will drop on one if you look hard enough though.
Im off to have a search around for another one in a second because as
standard they are a little small and not big enough for my next setup
so i need another one to build onto what i already have to get everything to fit
on properly with my new bits and bobs im wanting to buy .
If i find anything interesting /usefull out though i will update here ...
I simply cut a scrap piece of plywood a bit larger than the profile of my largest MB, used the MB as a stensil and drilled 1/4" holes about 3/8" in depth for each mounting screw position.
Then I mounted the HW to the MB (screws and spacer nuts), used 5 min epoxy to fill each of the 10 holes and let the bottom spacer nuts sink into the epoxy to the top the threads while still on the MB (being careful to use shims to set the correct spacing off the board).
Then I let it fully harden and unscrewed the MB...leaving the spacer nuts "Planted" on the plywood board permenantly.
Works like a charm, and it anchors the board ito a position that allows you to easily plug and unplug cables and such without flexing the board. And it works for all of my MBs.
Took a $1.00 set of mounting HW, $4.00 for epoxy, and 20 Mins to do.
I thought I'd resurrect this thread -- I have a High Speed PC Tech station now and am running the logic board on the foam that came from the manufacturer (MSI) under the motherboard -- it's thicker than the tech station's anti-static foam.
Who else is running like this? Any possible harm in doing this? I guess it won't melt and I guess it is anti-static? Thank you!
Old Standby:
NEC ND-3520AW Black
Anti-static...yes.
Melt? Also possible if you're air cooling and really cranking some volts overclocking through a hot chip, but your chip would probably fry before you have to worry about the foam melting underneath the socket thru the MB.
I've run boards on numerous foams, none melted on me but maybe I've been lucky (cautious). And never ran more than 2V without watercooling.
U should b ok.
Latest: Asus K8n4-e Delux, Mobile 3400 with 1 Mg cache, 754 PCI-E goodness, 7800GT. Four other AMD rigs and a Dell notebook.
Thanks zippyc!
Old Standby:
NEC ND-3520AW Black
Since its been resurrected, here's my Lubic based test bench setup:
Thread here.
navig
Navig's list of mod links ~ Exoframe Mini ~ Cabinet PC ~ Vertical Benching Station ~ Brass Tacks ~ Exoframe 2.0 ~ Project Vitis ~ Project Resilience ~ Very Low Cost Benching Station ~ The Exoframe Project ~ Jewel Box Project ~ DIY Benching Station ~ Console Project ~ Project Dark Side ~ Tower PC ~ Dual Tower PC ~ Bench Rig ~ My only standard case
I believe http://heatsinkfactory.com/cgi-bin/HFAstore.pl has them
HighSpeed PC sells “Tech Stations” standard and large, they also sell the Tech Station Accessories, e.g., ATX power switch, Reset switch, System Speaker, Power LED, and IDE LED.
http://www.highspeedpc.com/Merchant2...e=Tech_Station
ASUS A7N8X Deluxe Rev II ~ Barton 2500 AQXEA0323 @ 2420MHZ
2x512MB Corsair 3200LLPT BH-5 ~ BFG AGP 6800GT OC
2x80GB Seagate SATA in RAID 0 ~ SB Live Plat 5.1 ~ Live Drive
Princeton LCD19D ~ Enermax EG651P-VE FMA ~ Enermax EG465P-VE(D)
DD M4 ~ M4 A ~ BIX II ~ Eheim 1260
DFI NForce4 SLI-DR ~ Winnie 3200 CBBHD 0449 MPM @ 2700MHZ
2x512MB G.Skill 4800LA ~ 2xBFG 8800GTX
2x74 GB Raptors in RAID 0 ~ Audigy II ZS
ViewSonic VP201s ~ PCP&C 510 SLI ~ Enermax EG465P-VE FMA
DD TDX ~ 2xM4 A ~ Weapon ~ Iwaki MD20
nice link
and zippyc i dont think many people have had problems wiht the static bag melting but thats just me
D2OL will be on and off this summer due to heat
man, i thought i was wierd, and then i started hanging out here at Xtreme Systems-Disposibleteen
Rig1-Sempron2800+,ABIT NF7-S REV 2.0,Radeon9200se,No-Name350watt PSU,
Maxtor80gigs harddrive,K-Byte 256mb pc2100 & Ultra 256 pc2100 Ram, No-Name CD-Rw Drive
I have one -- great vendor -- I want a better foam pad though than the one it comes with.
Old Standby:
NEC ND-3520AW Black
These have pretty much replaced the Senfu Station if you are still looking for one. Hard to beat Senfu, but these come pretty close. Also have supply of premade switched and LEDs, always handy. HighSpeedPC is a reputable vendor as well.
Main Rig: Gigabyte GA-965P-DQ6 (rev. 1.0) cooled by the Monster Water Cooling Setup
HTPC One BIG Case
Current PC Count:
ASROCK: 1 * BIOSTAR: 1 * ASUS: 5 * CHAINTECH: 7 * GIGABYTE: 2 *IWILL: 1 * MSI: 3* TYAN: 2
175+ GHZ total power for PC Perspective Killer Frogs Climate Prediction Team as The Uncle B's!!
and more coming all the time!
I'm the Uncle your Aunt won't talk about. Go ahead and pull my finger!
At one point I was going to get the Tech Workstation, but then I thought. Hey I can build something myself and make it exactly how I want it for my particular situation and hardware. link below for those that haven't seen it yet.
My Xtreme Tech Workbench
current computer aresnal
A64 3200+ / DFI "LANPARTY nF4 SLI-DR / 1Gig Gskill LE / 6800GT / watercooled (custom radiator/Maze4 gpu/TDX/AquaExtreme50Z)
a64 3200+ / MSI K8N Neo2 / 6800gt agp
a64 3200+ / MSI K8N Neo2 / 6600gt agp
AthlonXP 1700 file server (almost 1 Terabyte)
3DMark2001 3DMark05
xtrmeme workbench
That's the way to go!Originally Posted by drftkng
Old Standby:
NEC ND-3520AW Black
This thread has been revived twice, it should be closed. Most of the information, other than the general stuff, is old and could confuse someone.
For those of you about to post:
if your mobo is plugged into the psu, and psu is plugged into the wall, it's already grounded
mobo: strix b350f
gpu: rx580 1366/2000
cpu: ryzen 1700 @ 3.8ghz
ram: 32 gb gskill 2400 @ 3000
psu: coarsair 1kw
hdd's: samsung 500gb ssd 1tb & 3tb hdd
If your wall plug is grounded and it works, that is...
Old Standby:
NEC ND-3520AW Black
