+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 45
Thread: testing motherboard outside of the case
    Xtreme Enthusiast sauria's Avatar
    Apr 2003
    North America, USA, TX
    0
    How many of you do this? I was considering setting it up on a towel and testing everything before installing it in my case. Is this dangerous? Do I need to set it on the anti-static bag it shipped in?
    I thought I once saw a picture of what looked like a motherboard mounting rig that was used for testing boards outside computers
    Old Standby:
    DFI LANPARTY nF4 Ultra-D (R.AD0) 623-3 BIOS
    AMD Athlon 64 3800+ X2 (CCBWE 0529SPMW)
    THERMALRIGHT XP-90 w/Panaflo FBA09A12H-1AZ 90mm (56.8cfm) - AS Ceramique
    MSI NX6600GT-TD128E GF 6600 GT PCI-E
    WD Raptor 74G Boot, WD 1200JB IDE
    NEC ND-3520AW Black
    OCZ OCZ600ADJ ATX 600W
    ALPS Black 1.44MB 3.5" Internal Floppy Drive Model DF354H121F
    Lian Li PC-60USB B2 Silver Aluminum ATX Mid Tower Computer Case
    Win XP Pro (32-bit) SP2
    Xtreme Member TheDogFather's Avatar
    Jun 2003
    Poole UK.
    0
    Set it up on anything that won't conduct, or make a mess on it.
    I see lots of pics of people just sitting it on the box it came from, the anti static bag can't hurt.
    Mine are just on a piece of cardboard.
    TDF.
    Infinity XP1700 247x9
    2x256Mb PC3500 Mushkin Level II 11-2-2-2-2-13-15
    Phase change in (slow) progress.
    Apr 2003
    0
    Ok, thanks TDF --- would they get too hot this way?
    Old Standby:
    NEC ND-3520AW Black
    Registered User Karnivore's Avatar
    Nov 2003
    0
    Well you still obviously need to cool the processor and your vid card unless its an antique As for setting up on Anti-static bags, It would be ok unless they are the Silver metallic looking variety. If it is indeed the Silvery metallic bag don't do it, they are conductive and it could possibly cause damage. A soft Static-free cloth, cardboard (shipping box) or most anything else no-conductive works well.
    Setting up for testing prior to install isn't a bad idea at all, just take your time, make sure cards are fully seated, nothing around to short anything etc.. Plenty of Xtreme folks around here don't even use cases
    Here is a shot of what your probably referring to as a "motherboard mounting rig" This is a Senfu Tech Station, pretty nice setup, unfortunately I believe they have been discontinued by the manufacturer...
    Jun 2003
    Poole UK.
    0
    No it doesn't seem to hurt them at all, I know many here run theres like that. Mine are flat out 24/7 like that.
    TDF.
    edit/ Hey I like that Karnivore, it sure puts my homemade wood attempt to shame.
    Nov 2003
    0
    Yeah they are pretty nice , around 40-50 USD. Have wiring, switches and all. Friend has two of them, one setup he uses, and another new in box.. Been trying to snag it from him for a while now, hopefully he'll get sick of my asking
    Apr 2003
    0
    Karnivore-- thanks, that's exactly what I saw. No place to get one?
    I have a so-called anti-static computer mat. I wonder if that'a a good idea?
    Old Standby:
    NEC ND-3520AW Black
    Xtreme Member Farbror's Avatar
    Mar 2004
    Sweden
    0
    I always have my MB in the case by Thats because it saves me some room for all the on my desk...
    //The Farbror....Has bad English and bad cooling...
    Nov 2003
    0
    Anything Nonconductive that won't promote static should work great, I've used, old books, cardboard, shiiping box, various pieces of cloth (no static cloth), wood, and anything else handy, long as it doesn't conduct electricity it should be fine...
    And NO, unfortunately I don't know anywhere you can get Senfu Terch Stations
    Apr 2003
    0
    Thanks, I was thinking about a towel over a box but wondered if that would be a static magnet like carpet?
    Old Standby:
    NEC ND-3520AW Black
    Nov 2003
    0
    Towels in my house are treated with an anti-static additive, LOL, so mine are good, but I could see that being an issue in some cases
    Apr 2003
    0
    LOL
    Ok, I live in a dry place but it's a humid spring day today. I'm doing all of this on a table that is NOT on carpet.
    Old Standby:
    NEC ND-3520AW Black
    Xtreme Addict LilGator's Avatar
    Jan 2004
    0
    it'sm always nice to set it up next to a window ac unit chillier than water cooling ... about 15 mobo temp/25 C on a Tbred @ 1.7v 2300MHz
    Dud3!
    Guest
    I wouldn't do the towel deal. A work bench or cardboard is what I use.
    X. I. P. sjohnson's Avatar
    Jul 2002
    Sioux Falls, SD U.S.A.
    0
    The Aerocool Lubic "case" is the closest thing to the Senfu, unless you get lucky at eBay or something and score a Senfu.
    Not cheap, at around $100 though.
    Reviews: http://www.viperlair.com/reviews/cas...ic/index.shtml
    http://www.tweaknews.net/reviews/lubic/
    The plural of "anecdote" is not "data."
    Apr 2003
    0
    Thanks all -- so far I've put it on a workbench on cardboard
    Old Standby:
    NEC ND-3520AW Black
    Dud3!
    Guest
    You can make something like that Senfu deal, it's just a square frame!
  18. #18
    Apr 2003
    0
    That Lubic case looks like a project in itself -- I basically want a test bed.
    Old Standby:
    NEC ND-3520AW Black
  19. #19
    Nov 2003
    Denmark
    0
    My rig when I didnt had a case.
    > ASUS A8V Deluxe
    > AMD64 3000+ Winny
    > Thermalright XP-120 med 120mm Pabst 24V@12V
    > 2 x 512 A-Data Viesta DDR566 (TCCD)
    > HIS 9800 pro IceQ
    > Audigy II
    > 3 stk Seagate 80GB + 1 stk WD360 (SATA)
    > Lian-Li PC65B + Lepont 470W
    > Philips 109B
  20. #20
    Apr 2003
    0
    Thanks DEEF. The lubic case looks like a way to run components out of a case permananetly. Anyone got pics of their lubic rig?
    Old Standby:
    NEC ND-3520AW Black
  21. #21
    Jul 2002
    0
    Send me $100 and I'll take some pics for you
  22. #22
    Apr 2003
    0
    Looks like a permanent project rig. ATX, BTX, CTX.....
    Old Standby:
    NEC ND-3520AW Black
  23. #23
    Xtreme Enthusiast Peckers's Avatar
    Apr 2003
    Sweden
    0
    If you want a more permanent solution like the "Lubic" etc. You could just get some aluminium L profiles and sheet metal, you probably have distances laying around. Not a big job to construct, glue it together will be strong enough and look clean. More fun(and cheaper) then getting something pre-manufactured.
  24. #24
    Apr 2003
    0
    Anyone know where to get the pwr & reset switches that attach to a board that is outside of the case? They come with the Senfu Tech Station
    Old Standby:
    NEC ND-3520AW Black
  25. #25
    Xtreme Addict kommando's Avatar
    Nov 2003
    Br!ban3 / Aus / State: St0n3d
    0
    Get one from old cases.
    Ripping it up on old technology
    i4memory.com
+ Reply to Thread
