Results 1 to 6 of 6
Thread: Water Chilling
    Dec 2003
    Woodridge, IL
    Talking Water Chilling
    OK, this is my water chiller. Actually I aquired two of these but gave one to my brother for his help in getting them running.
    http://www.ftssystems.com/multicoolbath.htm
    Here are some pictures (warning, they are Large). I need to find a better way to host these!
    http://home.comcast.net/~kcrose8104/index.html
    Anyway, keeping my Barton @ 235X9 (Work In Progress) at -3C
    (diode) and the MCW50-T on my 9700 Pro gets frosty!
    I need to blow out the evaporator with compressed air and do a bit more insulating.
    Lost an A7N8X-D to this mod (http://www.xtremesystems.org/forums/...threadid=28829) but replaced it with a DFI Lan Party NFII Ultra B This board rules for FSB. I don't think 250+ is going to be a problem
    DFI LP NF2 Ultra B
    AXP 2500+ (235*10)
    1GB Corsair TwinX 3200LL (1.1)
    ATI 9800 Pro (425/365)
    MCW5000-A,MCW50-T,MCX159-A
    WD1200JB, Liteon DVD/CDRW
    21" CRT, etc..
    Jan 2004
    I dont have any suggestions but i have a question..lol....Does a watercooling system cast more or less than a liquid chilling system??(Take for example they are both top of the line)....And approximately how much more or less??
    ________QUIKSILVER_______
    Banned
    Nov 2003
    portland oregon
    In my opinion a window ac chiller is the cheepest easiest most efective way to go. I can't comment on production stuff do to lack of experience there, but I'm sure production stuff cost way more and does less.
    Jan 2004
    oh k thx
    X.I.P.
    Jul 2003
    Darby FL, USA
    Hmmmmm... A cascade chiller. Interesting. What refrigerants does it use? What kind of coolant fluid is used at -80C?
    Author - Refrigeration Trouble Shooting Books
    Want to learn more? Click Here
    Dec 2003
    Woodridge, IL
    The chiller uses R13B1 and Propane.
    If you need operation @ -80°C you need to use anhydrous methanol or an expensive flourosilicone fluid.
    Just some more recent observations:
    1) @-10°C I was getting severe condensation No problem at >0°C
    (no condensation) or <-20°C (frost). Fortunately I was AG after a
    little time spend using a hair dryer on it.
    2) This damn thing is NOISEY (probably as bad as a tornado fan!)
    I should have gone with my original plan which was to drill holes
    in the wall of my house and locate the chiller outdoors under my
    deck! Also it is vibrating my entire desk at a high frequency! Oh
    well, I can always do that later anyway.
    3) It probably isn't good to send your parts from ambient -> -20°C
    more or less instantly! I am pretty sure that my brother smoked
    his ASUS 9800XT that way on Sunday (thermal shock). Here's
    hoping he can get an RMA since there isn't any obvious
    damage.
    4) I think my case temp of 15°C is pretty cool
    DFI LP NF2 Ultra B
    AXP 2500+ (235*10)
    21" CRT, etc..
