Im searching for a soldering iron with a thin tip thats short and can be held closer to the bottom like a pen.
I searched but failed, little help please.
Abit IP35 Pro
Intel Q6700
Crucial Ballistics Tracers 4x1gb 1066 DDR2
ATI X1800XT
Seagate 250gb / 750gb SATA
OCZ 600w
Swiftech Storm, GPU, Pump, Res, BI GT240 Stealth
I haven't seen one of those. If there is one, I imagine it would be a lower wattage in order to not burn your fingers that close to the tip. That's the reason for the long shaft on most irons, the shaft is designed to dissipate the heat before cooking the handle
I suppose you've already tried places like Mouser and Digikey.
I would think that a 15 watt iron would be low enough for a design of that nature...I suppose you could experiment and make one...using the right insulation it just may work.
Q6600 @ 3.4ghz 1.33v
Evga 680i
8800GTS 640
2gb Adata Extreme
OCZ Gamextreme 600w
The Weller WLS comes to mind, I know there are also a number of less expensive micro soldering pencils, although I've had no experience with them. The Basic WLS is not cheap, a little shopping should find one for about $200 I've used one for a quite some time and its one of my favorites.
LINK
The Link is just a quick google of it, shop around if/when you purchase.
sweet!...never seen that before.
of course...I don't solder or look for soldering tools that much either....
Evga 680i
8800GTS 640
2gb Adata Extreme
OCZ Gamextreme 600w
that's a NICE tool!
C
EXPENSIVE!
E6600 @ 3.2ghz (400x8), P5B Deluxe, 2GB Ballistix DDR2-1000 @ 600mhz 5-5-5-15, X1950 Pro, Antec Neo HE 500w
wow $400 for that? i can see why but still... that's a lot of money
Not exactly intended for the casual Vmodder, and if you shop around you'll be quite a lot less than that...
If you've ever had a cheap wrench break and smash your knuckles, its the same kind of thing here... You get what you pay for...
Ive got a spare Weller w/microtip I'd let go for $100+ shipping
I still have a Weller EC1001 iron, with 3 spare micro point tips. Anyone doing a bunch of vmods for freinds/family could make it worth buying.... $100+shipping.
I also have a weller like that.. although im keeping mine.
dremel down the tip of an existing tip to very fine point
Intel 2600K @ 4.8ghz 1.31v on Water.
ASROCK Z68 Ex4 Gen 3, 16GB G.skill pc1600
MSI GTX 680 1200/6800mhz
2x Vertex LE 60GB Raid 0
that's exactly what I did
Evga 680i
8800GTS 640
2gb Adata Extreme
OCZ Gamextreme 600w
Why don't you just buy a dull tip and then use something like a Dremel to sharpen.
try ebay, just picked up a couple for £2.50
CPU:Intel i5 750 @ 4200mhz 200x21 1.344v
Cooling: Corsair H50
Mobo:Gigabyte P55-US3L
Memory:4GB Corsair XMS3 9-9-9-24
GFX:ASUS HD5850 850/1200 1GB
This is my "professional" soldering station.
http://www.afrotechmods.com/cheap/iron/iron.htm
For those of you about to post:
I use a butane Iron. It heats up about 2x as fast as electric and it is adjustable. It has a thin pencil tip and only costs about $40 (canadian). Works great for vmods.
If my answers frighten you, stop asking such scary questions...
- Hush V2
- Intel i7 4770K - XSPC Raystorm - Gigabyte G1.Sniper Z87 - Crucial Ballistix DDR3-1866 - 9-9-9-24
- Zoltac Geforce GTX 780Ti - EK-FC780GTX Ti
- SanDisk Ultra 480GB SSD - WD Black 1TB 64MB Cache
- Custom Water Cooled Fractal Designs Define R4 - Antec HCP-1000 Platinum
- EK Coolstream XTC 280 - Cougar CF-V14HB Vortex HDB - XSPC EX240 - Scythe GT AP-15
- Dazmode Storm DDC 3.25 - AquaComputer Aqualis DDC 150 Reservoir
