Should I trade my A64 3000+ +25 dollars for a A64 3200+. His is a OEM and mine was retail.But I am keepign my hsf and everything. Is it worth doing this?
depends, what does his chip oc to?
if you dont want to oc it then yes, its worth it. if you plan to oc and his chip ocs the same or more then get it, if not then keep your own as the cache doesnt matter that much, at least in games.
He said the highest it has done is 2.35ghz..That the highest my 3000+ has hit too..So idk..
trade!!!
Dell Studio XPS16... no desktop
yes i have AIM, yes you can send me a message. EvilSpork3 i dare you.
yepp id trade
trade! and depending on ur temp's and oc skills his accomplishments with it might be less than what u can get. good luck!
Asus A7N8X-E Deluxe
Athlon XP 2800+ Barton @ 3200+ (200x11)
Mushkin DDR400 BASIC 2*512mb
Albatron GeForce 6600GT 128mb (Being Repaired)
Samsung SyncMaster 730BF 17" (4ms RT, 600:1 CR)
