Results 1 to 16 of 16
Thread: Still shaky, but running! HELP
    Jul 2002
    All,
    As I said earlier, I replaced the Gigibyte mobo and OCZ stick for
    KX7 333R and Corsair pc3200C2, Since I fired it uo and put a new install of xp on it, I've had nothing but problems! I've had to reinstall XP 4 times, as it continually has corrupt/missing file errors about <windows root> \system32\ntokrnl.exe or
    \windows\system32\config\system I also installed a new HDD
    These errors are non recoverable and the system will not re-boot into windows no matter what I do with the bios (defaults)
    It does this when I start messing with FSB, at 150 it dies. It's some Windows XP related problem??? When I toggle through the user definable CPU types it displays xp2100/xp2200, so I think it's a current enough mobo to recognize the unlocked xp2200. I just changed the bios to 133 X 10 and it's still running. Here's all
    SoftmenuII
    CPU Op Speed - User Define
    CPU FSB - 133
    Ratio (FSB:AGP:PCI) - 4:2:1
    Multiplier - 10
    Speed Error - Dis
    Enhance for benchmarks - dis
    DRAM clock - by spd
    Dram timing - manual
    Cas - 2.5
    Bank Inter - dis
    Trp - 3t
    Tras - 6t
    Trcd - 3t
    Dram Queu - 4 level
    DRAM command - 2t command
    I know the memory and board are good for more, but I'm afraid to crash windows again...Do you guys see anything?? Should I flash the latest bios?? And how? The website gives very nebulous directions on flashing the bios. Is Win XP unstable?? Any suggestions please!!
    F&S
    Xtreme Relic
    Jun 2002
    Hilton Head, S.C.
    I would examine your unlock job on the cpu...will it let you select different multipliers and actually boot with them?
    Are you upping the core voltage when it fails at 150fsb? What is your current core voltage set to?
    Sep 2002
    Farmington, MI
    What drive are you using ?
    I have two hdd's here that DIE at 155fsb.
    Western digital BB drives.
    DFI Lanparty NF4, A64 3200+ @ 2.5, 1gig BH5/6, 80GB JB, 2x 120gb seagate SATA Raid 0.
    HeatWare|My 04 R/T Neon| My Best Aircooled 3dmark|1.07TB Raid5 Linux Server
    Sep 2002
    UK
    Try 166 fsb with 5:2:1 ratio, then the PCI/AGP bus is not overclocked. PC3200 should run max timings at that speed.
    Note that on my KX7-333, LOWERING the cpu multiplier requires a CMOS reset otherwise it doesn't work. What a pain.
    Jul 2002
    Thanks all,
    Yes the cpu unlock is good, on the previous mobo and this one I have all multi's. I put in a new Maxtor d740x 40gb. And the default core voltage is 1.66, do I need to up the voltage only going to 150?? And to reset your multi, you've got to shut her down, clear the cmos and start her up again?? How about the flash??
    F&S
    Xtreme Relic
    Jun 2002
    Hilton Head, S.C.
    I dunno if you would need to up voltage at 150...but if it fails..it is worth kicking it up a notch to see.
    Jul 2002
    UPDATE:
    Running at 10 x 165, going to burn in the rig overnite @1.69v
    We'll see...
    F&S
    Jul 2002
    And another, tried 167 and got blue screen with error info, it was recoverable and as MS says a "serious error"
    It said these were the naughty files...
    C:\WINDOWS\Minidump\Mini091302-02.dmp
    C:\Documents\Myname\Locals~1\temp\WER2.tmp.dir00\s ysdata.xml
    Any ideas????
    F&S
    Aug 2002
    looks like your ram is crapping out (hard to believe) or your HDD. is your hdd getting hot? tried upping voltage supplied to cpu/ram? tried swapping ram in diffrent slots? always use 5:2:1 ratio no matter what. tried upping VIO? maybe your VGA doesn't like high fsb(?) tried lowering multiplier as low as possible and cranking up fsb as high as possible? (to rule out crappy ram stick) tried getting rid of all (i said all) pci cards? disabling USB ports?
    2600k @ 5.0Ghz 1.54V, Giga Z68, Zotac GTX680 AMP!, Patriot 1066Mhz 8GB RAM, Custom water, Silverstone 1000W, HAF932
    Sep 2002
    UK
    I have the same mobo, hd and worse memory (Corsair PC3200 CAS2.5) than you and I've run 3dmark on a 210 fsb with no problems apart from agp tearing.
    But I get best results at 175fsb with max memory timings - 12016.
    These are my settings (Athlon Tbird 1.33);
    Softmenu III
    CPU Speed - User Define
    CPU FSB - 175
    Ratio (FSB:AGP:PCI) - 5:2:1
    Multiplier - 8.5
    Speed Error Hold - Disabled
    Enhance for Benchmark - Disabled
    Core Voltage - 1.85v
    DDR Voltage - 2.85v
    CPU Fast Command Decode - Fast
    DRAM Clock/Drive Control
    DRAM Clock - 166
    DRAM Timing - Manual
    DRAM CAS Latency - 2
    Bank Interleave - 4 way
    Trp - 2
    Tras - 5
    Trcd - 2
    Enhance DRAM Performance - Enabled
    DRAM Access - 2T
    DRAM Queue Depth - 4 level
    DRAM Command Rate - 1T
    Put the memory in DIMM1, not DIMM4 like it says in the manual. Until I did this I couldn't get it above 173 with max timings.
    You have to clear the CMOS when putting the cpu multiplier DOWN, going up is ok. Or set cpu speed to lowest possible and power off. If you don't you'll get those ntokrnl.exe/system boot errors like you said in the first post. This is mentioned in the manual (page 3-5 "if the CPU is slower than the old one (and is same brand and type)").
    I haven't flashed my bios yet, still running the original 7M.
    Good luck!
    Overclocking Guru
    May 2002
    SoCal, USA
    Sounds to me that this memory sucks fireandsmoke, I would play with the timings, also just for testing try turning off 4 way on this memory and see what happens.
    OPP
    Jul 2002
    Maryland
    I don't get it.
    That is exactly the way XMS3200 CAS2.5 v1.1 acted on mine but the CAS 2 stuff is supposed to be good stuff.
    Put 2.85 volts on that memory and put at least 1.75 on the processor they do seem to burn in, I run mine at 1.82. You gotta have decent cooling.
    I can run my ram at 210 2.5 2 6 3 2t fast command decode (you aren't trying ultra are you?) with enhance dram perfomance and enhance for benchmarks on. I use Xtrmemddr PC3200.
    210
    Anything above that and AGP tearing sets in.
    I run 7x24 at 200 2.5 2 6 2 2t and all the other goodies turned on.
    Try slot 4 for the ram also.
    Good luck and you may have to look into your psu.
    Shad
    I knew where I was when I wrote this...
    I don't know where I am now.
    GB P35-DS3R q6600@3.15 Kubuntu Linux
    Asus P5B-DLX q6600@3.0 Ubuntu Linux
    GB 965-DS3 e6420@3.2 Gentoo Linux
    Asus Commando e6420@3.2/1950XTX Winders/VMWare/Kubuntu
    MSI Neo2 Plat Opty170@2.8 Debian Linux times 2
    IMac 2ghz c2d OSX 10.4
    Xeon Dualie 3.2Ghz Ubuntu 6.10 times 2
    Sep 2002
    UK
    That's what I've got. It'll run 2.5-3-6-3 2T @ 210 but only with Command Decode set to Normal. I guess that's why 2-2-5-2 1T @ 175 gives me a better 3dmark result?
    I also thought the XMS3200C2 was supposed to be much better. The specs say it does 2-2-2 1T @ 166 and 2-3-3 1T @ 200. If it doesn't send it back!
    Jun 2002
    Saskatoon, Saskatchewan
    I suspect that the issue is your hard drive, or some other PCI device. Have you tried running it at 166MHz FSB with the 5:2:1 ratio? If that is the problem, it should solve it.
    I had a similar thing happen to me. I had the FSB overclocked to 166MHz, and it was running half decent, so I went in the BIOS and changed all the performance enhancing settings to the best performance (CPU command decode to ultra, enhace DRAM performance, CAS, RAS, etc....) got a BSOD going into XP and found out that it had nuked my partition table. So in my case it was the RAM.
    AXP1700+ JIUHB 0302 @ 2400MHz - TEC-Watercooled in The Skyscraper
    ABIT NF7-S , Sapphire Radeon 9500 Pro, 1.5GB XMS3200C2
    XS IRC channel: irc.quakenet.net #xtremesystems
    www.ocfaq.com
    Xtreme Relic
    Jun 2002
    Hilton Head, S.C.
    If you hit 166 fsb and the 5 divider..I'm pretty sure you have to set the command from ultra to fast for it to work...at least I did
    Jul 2002
    Guys,
    You GUYS ARE THE SH*T!!!!!!!!!!!!!!!
    Yup, 5 divider, fast setting, and voltages...
    Check out new thread "A little better"
    'cause I don't know how to post attachments in Post Reply
    THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    F&S
