nice job stang
i wanna see some benchies:thumbsup: u gotta it into shape
nice job stang
can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
nice!!!
if the temps are alright pump some more vcore into it
primestable for a few hours= 90%stable, enough for a 3ghz oc
nah, it's not prime stable at all.
i can't even get it to 2.92 stable
oh well, just gotta get another screenie at 3076Mhz...
does this count me into the 3Ghz club though ??
right now you are the club
Yes, the club of very few. Superb job stang!
I don't think we will see 3.0 on air anytime soon. Mabey next year, lol. If AMD decided to rls a 0.09 core, I think it could easily happen.
I am was runn 2.678 on air yestarday.
AMD Powerhouser!
Tower: CoolerMaster Elite 371 | PSU: ThermalTake Smart M 850W
CPU: AMD FX-8350 @ 4.6GHz on 1.4V's | GFX: HSI IceQ X2 R9 280X 3GB @ 1250MHz/1630MHz
MOBO: M5A99FX PRO R2.0 | Mem: 8GB Corsair Vengeance DDR3 1600 (9-9-9-24-1T)
HDD: Primary'd: Seagate 600 Pro 240GB SSD-Slave'd: Hitachi 1TB | Media Drive: ASUS DVD-Burner
Cooling: Tower - 1990's Old School Lasko Box Fan|CPU - CoolerMaster Hyper 212 EVO with (2x) Silverstone FHP-141Push and Pull|GFX - Stock|NB - Stock|SB - Stock|Mem - Stock
Temps(in Idle/Load Key) No OC: CPU - 28c/48c|NB - 22c/24c|GPU - 28c/45c| OC'd: CPU - 30c/56c|NB - 22c/24c|GPU - 29c/54c
http://www.3dmark.com/fs/2325886
Maybe it should just be 3ghz on any cooling because thats a good milestone for aynone.
kudos
3 ghz on air isn't all that farfetched, some places it do get very cold during the winter. A few places in my country temperatures can plommit to below -40 C during winter. Put the rig outside in those tempertures and 3 ghz on air would be feasible.
Totally agree with shep,
congrats on the overclock
Stang_Man
Seasonic Prime TX-850 Platinum | MSI X570 MEG Unify | Ryzen 5 5800X 2048SUS, TechN AM4 1/2" ID
32GB Viper Steel 4400, EK Monarch @3733/1866, 1.64v - 13-14-14-14-28-42-224-16-1T-56-0-0
WD SN850 1TB | Zotac Twin Edge 3070 @2055/1905, Alphacool Eisblock
2 x Aquacomputer D5 | Eisbecher Helix 250
EK-CoolStream XE 360 | Thermochill PA120.3 | 6 x Arctic P12
Fark im not oc'ing with a freezing ass.Originally posted by Shep
Luckily where i live it gets to no less then 5 degress but thats bad for benching but hey its called aircon.
No kidding. You really can freeze at -40c...
Then again you could just run some lines, and operate it from inside your house.
Just hope you don't have to ever reset the CMOS
System
ASUS Z170-Pro
Skylake i7-6700K @ 4600 Mhz
MSI GTX 1070 Armor OC
32 GB G.Skill Ripjaws V
Samsung 850 EVO (2)
EVGA SuperNOVA 650 G2
Corsair Hydro H90
NZXT S340
hard drive, power supply, and cdroms dont work at that temperature.
good luck
Your best bet is to run piping to the stuff you wanna cool from inside.
actually power supplies can handle more watts at lower temps. like the rating on most power supply is what it will deliver at 40c, but in the manual they sometimes say that it can deliver like 100w more at 25cOriginally posted by Stang_Man
good luck
I'm pretty darn sure a PSU can work at -40c, look at your local power station....
The fan might not work, but who needs a fan at -40c?
System
ASUS Z170-Pro
Samsung 850 EVO (2)
Corsair Hydro H90
NZXT S340
Stang_Man is your mach1 modded and what temp's are you getting via lcd, bios, windows which ever seem the most correct.
Nice going Stang
CAn i just ask, is anybody that gets these high overclocks using the IDE channels on the NF7's?
I have two of the things, and every time i try to go over 2500mhz i loose ide
So are you guys using sata hdd's or an ide raid card or summit?
Chers peeps
From my seeing, most people use ide raid cards to oc in the regions. Always could use sata beats wasting a pci slotOriginally posted by Bundles
Nice going Stang
Chers peeps
Power suplies DON'T WORK at -40, nore does anything with an elcetrolytic capacitor on or in it, that includes most MOBOs. The electrolyte just freezes and the thing gives up. Your CMOS battery will also freeze to death.
- In Shadows Growing Wings -
I ran all my drives on IDE when I used to clock my 1700+ so 2.8GHz and I didn't notice a problem. Maybe because my ram was at 188MHz
Not bad at all.Wish I could get that OC.
Abit KN9-SLI
X2 3800+
1gb corsair pc5400
2 evga 7900gt
200gb maxtor sata
ocz 520w
heatware:althes
ebay althes
at 25C. that's pretty warm. 0C is freezing, and -40C is very cold. My power supply didn't have good voltages at 15F (~-12C??)Originally posted by blinky
^^Originally posted by Total Immortal
nope, not modded.Originally posted by jonspd
LCD = -29C full load
BIOS = 19C full load
Windows = 22C full load
I think windows is the most correct temp. The NF7 has awesome sensors, and the temp sensor touches the back of the cpu right under the core. the voltage sensors are also great being right on with what a multimeter reads.
I dont loose IDE at high fsb, however i've noticed now in my room, at 70F, i loose PS2 ports and floppy at FSB 240 or higher and vcore of 2.06V or higher. USB fixes that.Originally posted by Bundles
Nice going Stang
Chers peeps
SATA is known to corrupt faster than IDE, even with a PCI lock..
