Ocoopa H01 PD Pro
Introduction
Winter is here! And there’s only one thing that can make a below-zero day feel at least tolerable electric hand warmers. Whether consciously or unconsciously, we all occasionally rub our hands together or blow into them on a freezing day. That’s because as the temperature gets dangerously low, our body directs most of the blood flow to our vital organs (as it should), making our fingers cold. You probably wear socks throughout the winter, but the hands are left exposed to do simple tasks like using your phone. Now, that warm cup of coffee won’t last forever to wrap your fingers around. That’s why you need some electric hand warmers to keep you comfortable and fully functional throughout the day. Battery-powered hand warmers come in a variety of formats, most of which are designed for portability and to easily fit into the palm of the hand. You charge them for a couple to a few hours beforehand, then take them with you for at least a few hours of warming. Many hand warmers are also designed to charge your mobile devices, making this an added benefit of going with a battery-powered option. Enter Ocoopa's H01 PD Pro.
Before we move on, here are the specifications as obtained from the manufacturer's website. It is available in two colors: Camo and Black:
Packaging & Contents
The Ocoopa H01 PD Pro comes packed in a nice black and orange package with the Ocoopa logo on top.
Inside the box, you will find a silicone lanyard.
User manual.
Type C USB charger cable.
It comes with a carrier pouch to keep it safe.
A Closer Look
Ocoopa's iconic upper wide and lower narrow design is more conducive to gripping than any shape.
It feels good and high-quality. Has like a bumper feel. Due to the extensive battery life it's pretty big but it fits nicely in my jacket pockets. It has some weight to it (again, good battery life necessitates bulk).
The device has 3 different power settings. The button on the top will toggle through your 3 warm modes.
The LED’s are small but certainly put out a good amount of light in the darkness.
The silicone protective ring can reduce 80% of the impact of a drop on the hand warmer.
The features don’t end there as the device is a portable 10.000 mAh battery pack to charge your USB powered devices.
Performance
It delivers double-sided warmth. It heat up pretty much instantly so you don’t need to leave it always on. Put it in a pants pocket or an inside jacket pocket until you need to warm your fingers. Turn it on to whichever heat level you can stand, wrap your fingers around them and put your hands in your jacket/coat pocket. Once your fingers are warm again, turn the unit off and put it back into an inside pocket until you need it again. It will last for 8 hours at a medium temperature. It took around 3 hours to charge (18W fast charging).
It’s waterproof and dust proof (IP45). This warmer checked both of those boxes.
Top setting is really hot if you ever need it and other settings are both really nice temperatures.
Final Thoughts
The Ocoopa H01 PD Pro was certainly a well thought out product, including gadgets people need and gadgets people want. Having it out camping and on the trail with us, it has proven to be a tough multi-purpose device. It is water resistant, dust resistant, breakage resistant and support fast charging. The ability to have a portable charger and hand warmer in such a small product footprint is really incredible and comes in handy. Heats up SUPER fast, a bit on the heavy side (but understandably so). It offers three heat settings. The hottest setting is too hot so most of the time the low setting works great (and uses less battery). It comes with a carrier pouch and an wrist lanyard.
At just $29.99 the Ocoopa H01 PD Pro is one heck of a deal. This 2-in-1 tool is a steal for all of the features they have packed in it. Just the 10,000 mAh battery would go for around $40. Having a rechargeable hand warmer, that lasts 8-9 hours is invaluable as everyone gets sick of trying to use the disposable ones. This small device should be on you at all times when spending time outdoors. It comes with a warranty so you can contact the manufacturer if there is a problem.
https://www.amazon.com/OCOOPA-Waterp...09BNCB63P?th=1
https://www.ocoopa.com/products/ocoo...mer-camouflage
- You may not post replies
- You may not edit your posts
Forum Rules
