Results 1 to 3 of 3
Thread: Patriot Viper Elite II 64GB memory kit
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Patriot Memory sent out two kits of the new Viper Elite II product line. At first glance we can see there is no RGB and a strong color scheme of red and black.
    I will be using memtest86 and AIDA64 for testing as these modules will go into a 3D scanning workstation where memory density is needed and I will start with 64GB kit first.
    My motherboard is the Asus STRIX Z590-i and has memtest86 in bios error testing as well as a "flexkey" option in bios to quickly recover back to bios.
    These 64GB kit have two XMP profiles, profile 1 sets just the primary timings and profile 2 sets some secondary timings as shown, both profiles are 20-26-26-46 CL2.
    At stock speed they pull just over 50K in AIDA64, not bad but not great. Middle of the road good performance at safe settings.
    Looking at the CPUZ, we see the memory identifies as Spectec, so it is made by Micron.
    After a few hours of tuning I was able to bring the AIDA64 score up from 50K to just shy of 54K, while this is less than 10% improvement I will use it and save the profile.
    Conclusion:
    These kits competitively priced for while delivering good performance for high density dual rank kits. I do not expect to see these putting up competitive numbers for used specifically for overclocking.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Xtreme Member Fritz_the_germ's Avatar
    Feb 2009
    New Joisy
    Nice try...
    what do ya think about this?:
    [IMG][/IMG]
    AMD 5950X@EK-Monoblock@ ASUS Crosshair VIII Hero|EVGA FTW3 3090 Ultra Gaming @H²O_watercool_Waterblock H²O@Mo-Ra3|Seasonic Fokus-GX 1000W|4*8 GB G.Skill@3800 MHz@16-16-16 |Gigabyte Aorus NVMe Gen4, Samsung 850 PRO 1 TB, Samsung 960 evo, 1 TB| Cooler Master CoSmoS II | LG UltraGear 38GL950G-B, 37.5" |Windows 10 Prof. 64 bit
    Jun 2002
    Las Vegas
    This kit has been rock solid, no issues. Acceptable for the density
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
