Results 1 to 2 of 2
Thread: COLORFUL Launches GeForce RTX 3080 Ti and RTX 3070 Ti Graphics Cards
    Xtreme Reviewer
    Apr 2011
    Colorful Technology Company Limited, a professional manufacturer of graphics cards, motherboards, all-in-one gaming and multimedia solutions, and high-performance storage, proudly introduces the COLORFUL iGame GeForce RTX 3080 Ti and RTX 3070 Ti graphics cards. The line-up consists of the Vulcan, Advanced OC, and NB models. The all-new GeForce RTX 3070 Ti NB takes a new look with its improved cooling and mightier design. The COLORFUL iGame GeForce RTX 3080 Ti and RTX 3070 Ti comes packed with premium features including the One-Key Overclock, customizable RGB lighting, and more to cater to different types of power users, gamers, and PC enthusiasts.
    Powered by the NVIDIA- Ampere architecture, the GeForce RTX 3080 Ti delivers an incredible leap in performance and fidelity with acclaimed features such as ray tracing, NVIDIA DLSS performance-boosting AI, NVIDIA Reflex latency-reduction, NVIDIA Broadcast streaming features and additional memory that allows it to speed through the most popular creator applications as well.
    COLORFUL iGame GeForce RTX 3080 Ti Vulcan OC-V
    Unique to the Vulcan models, the COLORFUL iGame GeForce RTX 3080 Ti Vulcan gets the same set of premium features including the signature LCD screen. The LCD screen can be used for status monitoring and personal customization, it can display GPU temperature, GPU load, core clocks, and others. The LCD screen can be flipped 90 degrees, allowing it to remain visible even in vertical graphics card mounting orientation.
    The iGame GeForce RTX 3080 Ti Vulcan packs a triple-fan cooler with a 13-blade cooling fan design and the iGame Vacuum Copper Plated Technics, delivering superb cooling to achieve high and stable overclocks. The graphics card also features COLORFUL's One-Key Overclock button at the rear I/O - a straightforward overclocking feature for instant performance boost to 1710MHz in just one push of a button.
    Specifications
    COLORFUL iGame GeForce RTX 3070 Ti Advanced OC-V
    The COLORFUL iGame GeForce RTX 3070 Ti Advanced graphics card is the top-of-the-line model. It also packs a triple-fan cooler in a premium metallic shroud with an "Energy Core" central fan with a sophisticated "Lighting Frozen" lighting effect. The Advanced OC model features five 8mm-diameter high-performance heat pipes for aggressive heat dissipation. The graphics card also features COLORFUL's One-Key Overclock button at the rear I/O, pushing performance to 1830MHz in just a push of the button.
    Specifications
    COLORFUL GeForce RTX 3070 Ti NB 8G-V
    The COLORFUL GeForce RTX 3070 Ti NB graphics card features a new look with its improved thermal cooling design and RGB lighting while retaining the eye-catching Black+Red Design. The improved cooler packs a triple-fan configuration and sports an aesthetic metallic matte shroud and gaming red accents. The three 90mm cooling fans quickly dissipate heat from the high-performance heat sink with six 6mm-diameter heat pipes with direct touch to the GPU.
    The GeForce RTX 3070 Ti NB features an RGB COLORFUL logo on the side, perfect for RGB lighting enthusiasts. The GeForce RTX 3070 Ti NB is a compact triple-fan graphics card measuring 300mm x 104mm x 52.5mm.
    Visit COLORFUL at Facebook: https://www.facebook.com/ColorfulGlobal/
    Visit COLORFUL at Instagram: https://www.instagram.com/colorfultechnology/
    Xtreme Mentor
    May 2008
    cleveland ohio
    why does it have the 12 pin connector ?
    instead of the normal 6 pin pin and 8 pin pci express power connector ?
    or even just 3 8 pin pci express power connectors ?
    HAVE NO FEAR!
    "AMD fallen angel"
    Quote Originally Posted by Gamekiller View Post
    You didn't get the memo? 1 hour 'Fugger time' is equal to 12 hours of regular time.
