Results 1 to 3 of 3
Thread: Modem question
    Mar 2007
    Modem question
    I am finally switching internet companies. I am needing a cable modem and they say it needs to be a Docsis 3. There are so many out there. Does the cable modem make a difference? I have never used one before so I'm kind of new to the cable modem stuff. Thanks.
    2-ASUS VS248H-P Black 24" Monitor, ASRock Z77 Extreme4 LGA 1155 Intel Z77, Kingston Hyper X Blu 16GB, EVGA GeForce GTX 570 HD
    Intel Core Xeon E3-1245 V2, NZXT Sentry Mesh Fan Controller, Koutech IO-RCM621 Front Panel Multi-format Card Reader, Asus BW-12B1ST Internal Blu-ray Writer
    SAMSUNG 830 Series 2.5" 256GB SATA III , HITACHI Deskstar 7K3000 HDS723020BLA642 2TB, HITACHI Deskstar 7K3000 HDS723020BLA642, Western Digital 2 TB HDD
    Antec High Current Pro HCP-750 750W TX, CORSAIR Hydro Series H60 High Performance Liquid CPU Cooler, Windows 10 Professional Retail, Antec P183 V3
    Dec 2004
    Southern California
    i would go with most commonly used which is the Motorola Surfboard model. Docsis3.0 will give you the full bandwidth you'll be paying for, there are older 2.0 modems but you wont want that. Are you in SoCal by any chance? I have a few modems laying around I dont have a use for.
    i9-10900k@5.3ghz//MSI MEG z490 Unify//32GB Gskill TridentZ b.die@DDR4666//RTX 2080ti(+150/+700) kingpin bios//Samsung 970 Pro//Corsair AX1200i
    Custom Loop: Dual DDCs->Dual EK XE360 w/GT's -> HK IV CPU -> HK IV GPU ->EK X3 Res controlled by Aquaero 6
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    If you need 3.0 and not 3.1 then it does not really matter. If it is 3.1 you need one from your ISPs qualified list. There is only one chipset right now with 16x4 or more, so they are really the same for 3.0.
    Newegg has a nice one on sale
    https://www.newegg.com/motorola-mb76...012-_-09212020
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
