Results 1 to 8 of 8
Thread: Ryzen 3700x
    Xtreme Cruncher
    Apr 2008
    Ohio
    Ryzen 3700x
    Thought I'd do some testing on a Asus Prime x470 Pro.
    Does anyone remember when AMD sucked at Super PI
    ~1~
    AMD Ryzen 3700X
    Asus x470 Prime
    Trident-Z 3200 CL14 16GB
    AMD Radeon 5700X
    ~2~
    AMD Ryzen ThreadRipper 2950x
    Asus Prime X399-A
    GSkill Flare-X 3200mhz, CAS14, 64GB
    AMD Radeon VII
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    Try 32M please, with process affinity to core 1+2. Im interesting how it scaling compare Pinnacle Ridge in 32M. On HWBOT are few results, but seems not good (like Pinnacle Ridge is better clock to clock in 32M).
    ROG Power PCs - Intel and AMD
    Xtreme Cruncher
    Apr 2008
    Ohio
    Here is a run with just PBO enabled
    ~1~
    AMD Ryzen 3700X
    Asus x470 Prime
    AMD Radeon 5700X
    ~2~
    Asus Prime X399-A
    AMD Radeon VII
    Xtreme Cruncher
    Apr 2008
    Ohio
    Depending on what I run, PBO seems to do very well
    4.3ghz CB15
    PBO CB15
    ~1~
    AMD Ryzen 3700X
    Asus x470 Prime
    AMD Radeon 5700X
    ~2~
    Asus Prime X399-A
    AMD Radeon VII
    Xtreme Cruncher
    Apr 2008
    Ohio
    Fire Strike did much better with the 3700x than on my 2700x. This run was done with PBO.
    This was with a Radeon VII on Custom water loop.
    2700x @ 4.3ghz, same RAM and GPU
    Last edited by charged3800z24; 07-14-2019 at 03:12 PM. Reason: Added 2700x comparision
    ~1~
    AMD Ryzen 3700X
    Asus x470 Prime
    AMD Radeon 5700X
    ~2~
    Asus Prime X399-A
    AMD Radeon VII
    May 2008
    Czech republic
    cool, try please also 4300 MHz Superpi 32M (+affinity on some cores and high priority). I would like to compare with my Ryzen Pinnacel Ridge Thanks.
    Xtreme Cruncher
    Apr 2008
    Ohio
    Here is the 4.3ghz run
    ~1~
    AMD Ryzen 3700X
    Asus x470 Prime
    AMD Radeon 5700X
    ~2~
    Asus Prime X399-A
    AMD Radeon VII
    Nov 2002
    MA.
    No longer sucks, I got 9.0754 on 32 with an un-optimized W10 install @4199-3200/14,PBO, 4190-4199.
    This is almost as basic as you can get, looking forward to learning more about W10 and Z2.
    Zen2 Has brought AMD back!
