Results 1 to 2 of 2
Thread: LIAN LI PC-T60B Black Aluminum ATX / Micro-ATX TEST BENCH Computer Case
    Assistant Administrator systemviper's Avatar
    Nov 2007
    Newtown, CT
    Anyone ever use this bench, is it any good, i am looking for a few good benches to set up
    a couple rigs at a time.
    I saw this and thought it looked interesting.
    The T60 Test Bench mounts standard ATX & Micro-ATX motherboards, 5.25" optical drives, 3.5" and 2.5" hard drives, and a standard ATX PS/2 power supply unit. The open design makes it easy to switch components, mod, and service.
    Open ArchitectureThe LIAN LI PC-T60 Test Bench case features a completely open design for easy hardware installation and removal, ideal for overclockers and enthusiasts. The open design and aluminum construction also enable effective, reliable cooling even without fans.
    5.25" Drive BaysTwo standard 5.25" optical drives mount directly above power supply unit.
    Removable HDD CageThree HDDs mounts are offered in the removable HDD cage with thumb screws, while the rubber suspension helps prevent vibration for better system reliability and stability.
    Support 2.5" HDDsAluminum mount for two 2.5" HDDs directly below the M/B tray allow users to easily install and remove them as desired.
    Rubber-Padded PSU SpaceThe power supply has rubber pads for both insulation and support, reducing vibrations and also securing the PSU without scratching the painted surface.
    Trestle for PCI Card StabilityA trestle can be easily set up with thumb screws, to give the back-end of the T60 Test Bench case additional stability.
    Learn more about Lian Li PC-T60B
    Model
    Brand
    LIAN LI
    Model
    PC-T60B
    Details
    Type
    Color
    Black
    Case Material
    Aluminum
    With Power Supply
    No
    Motherboard Compatibility
    Micro ATX / ATX
    Expansion
    External 5.25" Drive Bays
    2
    Internal 3.5" Drive Bays
    3
    Expansion Slots
    8
    Dimensions & Weight
    Max GPU Length Allowance
    230 mm
    Max CPU Cooler Height Allowance
    150 mm
    Dimensions (H x W x D)
    15.70" x 12.90" x 13.80"
    Weight
    3.97 lbs.
    Additional Info
    Features
    Lian Li Fine Craftmanship Product
    To ensure user can put everything together easily, Lian Li designer decided to use only standard PC component inside the T60, standard 5.25" optical drive, standard 3.5" hard drives, standard ATX PS/2 power supply units. The parts are easy to get on current market, and it would be easy to upgrade and server in the future.
    T60 is a Mini-ITX TEST BENCH system, it supports standard Mini-ITX motherboard on the top, therefore install this tiny board can be very easy.
    The power supply has rubber pads for both insulation and support. reduce vibrations and also secure the PSU without scratching the painted surface.
    There are two space for standard 5.25" optical drive above the power supply unit.
    T60 features Anti-virbation HDD cage, which allow user to fit three of 3.5" HDDs. It is easy to use, no tool required, simply using the special thumb screw to secure the anti-vibration rubber ring to the HDD, and slide the HDD into the cage.
    T60 is a ATX / Micro-ATX TEST BENCH, it equipped with 8 PCI slots, especially in the advent of adding in new graphics cards.
    There are two aluminum handles for 2.5" HDDs below the M/B tray, allow user to install or remove 2.5" HDD easier.
    HWbot - Team: XtremeSystems
    XS cruncher - Team: XtremeSystems
    OCN Feedback
    HEAT
    *** Being kind is sometimes better then being right.
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    I saw this at CES last year, quality seemed good.
    As for benching my issue was the top support arm above the mobo was in the way for no reason. I guess if you don't use LN2 or phase change its good with HSF and AIO. LN2 probably fits but as you can see you have to work around that bar.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
