Results 1 to 4 of 4
Thread: A litlle blast from the past - overclocking an i3 540
    Xtreme X.I.P.
    Jun 2002
    Tel Aviv, Israel
    So I have had this i3 540 on the MSI H55M-ED55 for more than 8 years now. I always ran it at stock frequency (I did OC the iGPU for a while at the beginning)
    I decided to play a little bit with it and see how far I can push it. The current setup is:
    i3 540, MSI H55M-ED55 on the latest (1.7) BIOS, 4x2GB DDR3-1600 G.Skill RipJaws RAM, Antec 380W PSU (Antec NSK2400 case), cooled by Arctic Freezer 7 Pro rev2 with AS5 as TIM, so temps are under control.
    I was able to clock it up to 4GHz without breaking any sweat, it even passed about 2 hours of linpack, and seems generally stable. But anything over that magic number feels like I'm hitting a brick wall.
    The mobo seems a bit finicky with high bclk and changing things like the memory multiplier or QPI multiplier, causes it to fail POST. After saving the settings it reboots, restarts a couple of times and POSTs with an error that the overclock has failed.
    Vcore is at ~+0.200v for about 1.3v, all the other voltages are at stock. Currently I have the XMP memory profile enabled, and so the memory is overclocked too. Changing the memory multiplier down to x4 fails POST sometimes, others it doesn't have any effect.
    I tried dropping the multiplier to see how high I can get bclk to go, to no avail. I have the iGPU underclocked, and I keep it at around or below 700MHz.
    I tried playing with VTT and PCH voltages, but it didn't do much of anything in getting this board much if at all past 180MHz bclk. I can get it to boot in steps, going from 174 to 180 then to 185, but if I change anything else it just refuses to POST.
    I know that this platform is ancient by today's standard, and 4Ghz is a 30% overclock, which is more than decent. But it's apparent that this chip can do more, maybe much more, but the motherboard or some tweaks I'm missing are keeping it back.
    I'd appreciate any advice on how to push it a little bit further.
    Member of Overclockers.com Folding @ Home team
    "<The_Coolest> you can't unwaste wasted CPU cycles" - Start FOLDing now!
    Main rig:
    AMD Ryzen 7 2700X / Mobo: Asrock Fatal1ty X470 / EVO 970 500GB + WD Blue 250GB + HDD / GPU: Dell RX 570 4GB / Mem: 2x16GB DDR4-3200 G.Skill 32GTZKW TridentZ - 32GB total / PSU: Seasonic Prime Ultra Gold 650W
    Secondary rigs:
    Core i7 2600K 3.4GHz @ 4.3GHz (Scythe Mugen2) / Mobo: Biostar TP67XE / 2x Inland Pro 120GB / GPU: HD5450 / Mem: 4x4GB DDR3-1600 G.Skill 8GBXL RipJawsX - 16GB total / PSU: Seasonic S12II 620W.
    Core i3 540 3.06GHz @ 4.0GHz (Freezer 7 Pro) / Mobo: MSI H55M-ED55 / GPU: Integrated / Mem: 4x2GB DDR3-1600 G.Skill 4GBRL RipJaws - 8GB total / PSU: Antec 380W.
    Core Temp - Accurate temperature monitor for Intel's Core/Core 2 and AMD64 processors
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    So long ago already, did you see any high bclks on this mobo on the bot? I would suspect it is the limiting factor.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Xtreme X.I.P.
    Jun 2002
    Tel Aviv, Israel
    Yep. I think I have had it for over 8 years now.
    Recently started using it as a Linux build machine. So I thought that a little bit extra oomph without spending much $ on upgrades of ancient h/w would be fun.
    Not a very popular board on the bot. Looks like there's just one entry of a i5 655K, surprisingly at the same exact bclk (174). I think that 4GHz is a decent O/C, just looks like the chip is capable of more.
    I read a review where they managed to get it way past 200Mhz bclk, but maybe it was just the luck of the draw.
    Main rig:
    Secondary rigs:
    Xtreme X.I.P.
    Jun 2002
    Tel Aviv, Israel
    Here's the review I was looking for: https://www.tomshardware.com/reviews...d,2555-21.html
    Main rig:
    Secondary rigs:
