Results 1 to 2 of 2
Thread: Overclocking G3258 with Asrock z97 Anniversary at 4.2ghz
    Sep 2007
    Hi guys ! I wanted to overclock this cpu G3258 at 4.2ghz with Asrock Z97 anniversary motherboard. Default at 3.2ghz is with 1.093v. The memory is Crucial Ballistix Tactical 2x4Gb (8-8-8-24 1600mhz) 1.35v. I need little bit help with this. With wich program can i change the voltage in windows without restart the windows and to check if that voltage is fine ? Thank you in advance !!
    E6850(L720 xxx vid:1,275v)lapped 3600mhz(1,264v)3800mhz(1,31v)4000mhz(1,39v)\\Ninja rev A lapped\\Dfi ut p35 t2r\\Team Xtreem 2x1gb TXDD2048M1000HC5DC (5-5-5-15 800mhz) 1,63v !!! (5-5-5-15 1100mhz) 1,91v (4-4-4-12 1000mhz)2,19v\\ Samsung 500gb F3\\Asus GTX 550Ti \\Enermax Modu+ 525w\\Case Fractal Arc Design Midi
    Aug 2007
    Germany/Bavaria
    Not sure if still relevant, but Asrock A-Tuning utility should just work fine for you. The version listed at the download section of your mainboard model is quite old though. So it might be worth trying a newer version of a tool listed e. g. for a Z370 mainboard.
    By the way a moderator should move the thread to the Intel subforum. The Xtreme Overclocking subforum is not meant for your daily overclocking needs.
    The Initial value finished
    PI calculation is done!
    Quote Originally Posted by Zeus View Post
    Software tweaks are not for sale.
