http://www.guru3d.com/news-story/nvi...ion-video.html
Researchers from Nvidia developed a method to use AI for the interpolation of video images. This makes it possible to convert a standard recording in for example 30fps into a slow motion video of, for example, 240 or 480fps. Check out the video below the fold, it's pretty impressive.
Researchers from NVIDIA developed a deep learning-based system that can produce high-quality slow-motion videos from a 30-frame-per-second video, outperforming various state-of-the-art methods that aim to do the same. The researchers will present their work at the annual Computer Vision and Pattern Recognition (CVPR) conference in Salt Lake City, Utah this week.
?There are many memorable moments in your life that you might want to record with a camera in slow-motion because they are hard to see clearly with your eyes: the first time a baby walks, a difficult skateboard trick, a dog catching a ball,? the researchers wrote in the research paper. ?While it is possible to take 240-frame-per-second videos with a cell phone, recording everything at high frame rates is impractical, as it requires large memories and is power-intensive for mobile devices,? the team explained. With this new research, users can slow down their recordings after taking them. Using NVIDIA Tesla V100 GPUs and cuDNN-accelerated PyTorch deep learning framework the team trained their system on over 11,000 videos of everyday and sports activities shot at 240 frames-per-second. Once trained, the convolutional neural network predicted the extra frames. The team used a separate dataset to validate the accuracy of their system. The result can make videos shot at a lower frame rate look more fluid and less blurry.
?Our method can generate multiple intermediate frames that are spatially and temporally coherent,? the researchers said. ?Our multi-frame approach consistently outperforms state-of-the-art single frame methods.?
