Results 1 to 12 of 12
Thread: New system for gaming and professional use
    Mar 2005
    Middle Europe
    Hi guys,
    after a long time with my old hardware, I need a new and strong PC system for gaming (medium - ultra) and professional (construction tools like UGS NX, E3D and video tool like Pinnacle).
    The professional tools need a lot of memory and cache (exchange datas ~1-10GB), so I need fast SSD and RAM.
    I also want to overclock the system (CPU, RAM), if possible.
    The specs:
    CPU: AMD Ryzen Threadripper 1900X or 1920X
    MAINBOARD: ASRock Fatal1ty X399 Prof. Gaming
    RAM: Corsair Venegance RGB 4x8GB, DDR4-3600
    SDD: Intel SSD Optane 900P 480GB, PCIe 3.0x4 (OS and Construction)
    SSD2: Intel SSD 760p 512GB, M.2 (General and Video)
    HDD: WD Re 2TB, SATA 6Gbs (Backup)
    GPU: Geforce GTX 1060 (the newest GPUs are too expensive, so I will upgrade after the prices are on a lower level)
    PSU: Corsair HX850i
    OS: Win 10 / Linux
    watercooled (I have my own fixed specs):
    CPU
    MOBO
    What do you think about this?
    Thanks.
    Mar 2005
    Middle Europe
    Any suggestions?
    Xtreme Cruncher
    Apr 2008
    Ohio
    The 1900X is basically the Ryzen 7 with QUAD Channel. I personally went for the 1950x and Asus Prime board (was on sale). Might as well go al the way!
    ~1~
    AMD Ryzen 9 3900X
    GigaByte X570 AORUS LITE
    Trident-Z 3200 CL14 16GB
    AMD Radeon VII
    ~2~
    AMD Ryzen ThreadRipper 2950x
    Asus Prime X399-A
    GSkill Flare-X 3200mhz, CAS14, 64GB
    AMD RX 5700 XT
    Mar 2005
    Middle Europe
    I just need TR4 because of the 2x M2 PCIe SSDs und what's your actual experience with your system?
    Xtreme Cruncher
    Apr 2008
    Ohio
    Been great, played with Hyper-V, VMWare etc , just testing what's new and some VDI stuff. I game and bench for fun and do some minor content creation stuff etc. Just acquired some M.2's to test with RAID.
    ~1~
    AMD Ryzen 9 3900X
    AMD Radeon VII
    ~2~
    Asus Prime X399-A
    AMD RX 5700 XT
    Administrator
    Nov 2007
    Stockton, CA
    I ran ASUS X399 Zenith Extreme + 1950x for a while, I do both work loads you want to do, work/gaming.
    In the end I moved back to my dual E5-2699v3 system. The main reason was AMD SMT, I ended up just disabling it as some games and programs just don't like SMT being on.
    Mar 2005
    Middle Europe
    @charged3800z24:
    Sounds good and what about your specs (compareable with my list)?
    Did you overclock your hardware?
    @buckeye:
    Interesting and overclocking was successful?
    What's exactly the problem with SMT (with the games and programs)? Crashes?
    And which apps? It could be possible, that some of them are the same.
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Keep the SSD's on the CPU and not the PCH, use add in card 900P's and not the M.2 if it uses the PCH.
    I agree that SMT off performs better is some applications. SMT enabled increases TDP quite a bit, measurable.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Administrator
    Nov 2007
    Stockton, CA
    Quote Originally Posted by GNU View Post
    @charged3800z24:
    @buckeye:
    Overclocking was a snap, I just used the predefined settings in the BIOS.
    The problem with SMT was mostly with games, many just do not like it. Most of the time they would just error out on startup so I found myself going back in forth into the BIOS to turn of or off SMT which I got tired of.
    https://www.servethehome.com/asus-ro...rboard-review/
    A lot of stuff just doesn't show up when reviewing. I did switch this over to my main rig for about a month, that's when issues show their ugly head.
    I know Patrick at STH is using a TR system, pretty much like mine. He does not really game and has no issues with his system. I think games are the problem.
    Xtreme Cruncher
    Apr 2008
    Ohio
    @charged3800z24:
    CPUz screenshot below with system details. I use Samsung 850 pro SSD's and a KXG 256GB M.2 as well as 1 AMD RX Vega 56. I've played several games without any issues such as Diablo 3, GMOD, Battlefield 4, Dota2, Minecraft (yes I said that), 7 days to Die, etc, etc. Always use SMT with all cores enabled. Haven't done a lot of OCing yet, just a quick 4ghz with Cinebench and other Benchmarks.
    ~1~
    AMD Ryzen 9 3900X
    AMD Radeon VII
    ~2~
    Asus Prime X399-A
    AMD RX 5700 XT
    Mar 2005
    Middle Europe
    Quote Originally Posted by Charles Wirth View Post
    Why? What's wrong with M.2 ?
    Quote Originally Posted by Buckeye View Post
    You tried overclocking?
    What's the difference with SMT? What it's useful for?
    It could be a CPU issue which will be removed with TR 2000 Gen. ?
    Quote Originally Posted by charged3800z24 View Post
    Wow, that's very cool.
    You are happy with the Samsung SSD M.2? It's better than the Optane maybe?
    Interesting thing is, that you can play with SMT and you didn't overclock (why?)
    @all:
    I could wait for the TR 2000. It's better than the TR 1000 and any issues are removed maybe?
    Xtreme Cruncher
    Apr 2008
    Ohio
    I have done some over clocking for test etc, just not for production use. The water cooler keeps this CPU nice n' chill so the XFR keeps it running at a nice boost. Haven't had a reason to OC due to that and with the RX Vega 56, gaming is pretty stellar. The M.2 is a Toshiba KXG and runs nicely. I have 3 Samsung SATA SSD's for my VM's, data, etc. Side note, I use the Windows high performance profile.
    ~1~
    AMD Ryzen 9 3900X
    AMD Radeon VII
    ~2~
    Asus Prime X399-A
    AMD RX 5700 XT
