Results 1 to 1 of 1
Thread: New build help
    Jun 2008
    New build help
    Hello everyone, I have come across a problem that I can't seem to solve, I am trying to figure out how to connect 2x360 rads into my system and running the fans off of my "Cpu_opt" header so that they will follow my CPU temp for the time being
    My current system -
    Haf 932
    6700k
    Gigabyte z170x gaming 7
    680 classified
    Pe360
    3x vardar 120 - "cpu_opt" fake 4 pin header(gnd, speed control, sense, vcc)
    D5 pwm pump - connected to "cpu_fan" header( only true 4 pin pwn header)
    New parts being addes
    View 71 tg
    Xe360
    6x dark side gentle typhoon 2250
    GPU block for nvidias next gen gpu
    I would like all 6 fans to be able to follow my CPU temps and adjust accordingly but I feel throwing 6 fans on the header without another source of power is a bad idea And because my header is not a pwm header I can't use a pwm hub, and the new case does not have any 5 1/4 drive bays so a regular controller is not an option
    is there an easy solution that I'm missing?
    Or is this unobtainable
