Results 1 to 5 of 5
Thread: [News] Intel AMT Security Issue Lets Attackers Bypass Login Credentials
    Join XS BOINC Team StyM's Avatar
    Mar 2006
    Tropics
    https://www.techpowerup.com/240566/i...in-credentials
    F-Secure reports a security issue affecting most corporate laptops that allows an attacker with physical access to backdoor a device in less than 30 seconds. The issue allows the attacker to bypass the need to enter credentials, including BIOS and Bitlocker passwords and TPM pins, and to gain remote access for later exploitation. It exists within Intel's Active Management Technology (AMT) and potentially affects millions of laptops globally.
    The security issue "is almost deceptively simple to exploit, but it has incredible destructive potential," said Harry Sintonen, who investigated the issue in his role as Senior Security Consultant at F-Secure. "In practice, it can give an attacker complete control over an individual's work laptop, despite even the most extensive security measures."
    Intel AMT is a solution for remote access monitoring and maintenance of corporate-grade personal computers, created to allow IT departments or managed service providers to better control their device fleets. The technology, which is commonly found in corporate laptops, has been called out for security weaknesses in the past, but the pure simplicity of exploiting this particular issue sets it apart from previous instances. The weakness can be exploited in mere seconds without a single line of code.
    The essence of the security issue is that setting a BIOS password, which normally prevents an unauthorized user from booting up the device or making low-level changes to it, does not prevent unauthorized access to the AMT BIOS extension. This allows an attacker access to configure AMT and make remote exploitation possible.
    To exploit this, all an attacker needs to do is reboot or power up the target machine and press CTRL-P during bootup. The attacker then may log into Intel Management Engine BIOS Extension (MEBx) using the default password, "admin," as this default is most likely unchanged on most corporate laptops. The attacker then may change the default password, enable remote access and set AMT's user opt-in to "None." The attacker can now gain remote access to the system from both wireless and wired networks, as long as they're able to insert themselves onto the same network segment with the victim. Access to the device may also be possible from outside the local network via an attacker-operated CIRA server.
    Although the initial attack requires physical access, Sintonen explained that the speed with which it can be carried out makes it easily exploitable in a so-called "evil maid" scenario. "You leave your laptop in your hotel room while you go out for a drink. The attacker breaks into your room and configures your laptop in less than a minute, and now he or she can access your desktop when you use your laptop in the hotel WLAN. And since the computer connects to your company VPN, the attacker can access company resources." Sintonen points out that even a minute of distracting a target from their laptop at an airport or coffee shop is enough to do the damage.
    Administrator
    Nov 2007
    Stockton, CA
    Just tried this on my main rig, CTRL-P on bootup does nothing.
    Feb 2010
    Does your BIOS/UEFI have MEBx?
    Administrator
    Nov 2007
    Stockton, CA
    Quote Originally Posted by drmrlordx View Post
    Nah... just tried it to see what it would do.
    This only effects enterprise equipment really.
    Xtreme Mentor
    Apr 2003
    Ankara Turkey
    Can we pass login of sites that are hosted on intel based servers?
    When i'm being paid i always do my job through.
