Results 1 to 10 of 10
Thread: Sandy/Ivy Bridge-E degration Experience
    Jun 2007
    for those who still running these chips share your degration experience. and how well is performance after about 5-6 years of use. Oc, volts, ghz etc.
    [FSB<>BCLK]
    3930k@4.3Ghz 1.3v/4.5Ghz 1.35v full load 24/7 Lapped~RIVG~Corsair AIO GT~Corsair Ven-Pro 2x8Gb@2.4Ghz 1.65v CL11~850Evo~GTX 1060 strix~Win8 X64~AX1200i
    SORRY FOR MY BAD ENGLISH
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    I was off this platform fast, did not even know it has a degradation problem.
    Intel 7960X ES @ 4.4Ghz
    ASUS Rampage VI Extreme
    GTX 1080ti Galax Hall of Fame
    32GB Galax Hall of Fame
    Intel Optane
    Platimax 1350W
    Enermax 240 Liqtech AIO
    Intel 8700K @ 5.2Ghz
    Asus Maximus X Apex
    GRX 1080ti Galax Hall of Fame
    16GB Galax Hall of Fame
    Intel Optane
    Platimax 1350W
    May 2009
    Upstate, SC
    Quote Originally Posted by xpower View Post
    I'm right at 5yrs i think since i built my current box. i5-3570k has been sitting at 4.6ghz under water since without issues. my previous q6600 had bad issues and by the time i got rid of it i was under 2.9GHz from its original 3.6GHz OC just to keep it halfway stable.
    SYSTEM
    i5-3750K @ 4.6ghz - ASRock Z77 Extreme4 - 16GB Samsung DDR3 - Sapphire R7 370 Nitro 4GB
    Water Cooling
    EK Supremecy - DDC-3.2 w/XSPC Top -Swiftech MCR320-QP - EK Multioption 150
    Xtreme Cruncher
    Nov 2008
    NE Ohio, USA
    Running since I got it 4.5GHz 1.260v full load crunching on World Community Grid 24/7/365 (baring any power outages) on a Corsair H70 without any stablity issues or voltage increases needed since in that time.
    Home PC -- 24/7 Cruncher #1
    GA-P67A-UD4-B3 BIOS F8 mod, 2600k (L051B138) @ 4.5 GHz, 1.260v full load, Corsair H70 (Boots into Windows @ 5.6 GHz per Massman binning)
    Samsung Green 2x4GB @2133 C10, Gigabyte 7950 @1200/1250, Vertex 4 128GB, 4x3TB WD Red RAID10, BR Burner, Win7 Ult x64, CM690, HX750
    Work PC -- 24/7 Cruncher #2 ... Crucial M225 64GB SSD Donated to Endurance Testing (Died at 968 TB of writes...no that is not a typo!)
    GA-EP45T-UD3LR BIOS F10 modded, Q6600 G0 VID 1.212 (L731B536), 3.6 GHz 9x400 @ 1.312v full load, Zerotherm Zen FZ120
    OCZ 2x2GB DDR3-1600MHz C7, Sapphire 7870 @1100/1275, Crucial MX100 128GB, 2x500GB Hitachi RAID1, Win7 Ent x64, Centurion 590, XFX PRO650W
    Music System
    SB Server->SB Touch w/Android Tablet as a remote->S/PDIF->Denon AVR-X3300W->JBL Studio Series Floorstanding Speakers
    Dec 2010
    PA
    I know you said sandy/ivy but up until a few months ago I ran a haswell I7 5930k@4.5ghz 1.2875v with air cooling (212 evo) with zero issues of degradation. Worked like the first day I fired up right until I sold it.
    Sep 2006
    I have experience with i5 2500k degradation its when you have to give it a lot of voltage to achieve 5ghz stable and over time you have to give it just a little more until your having to reduce clock speed to keep it stable, and giving it more volts/ doesn't help just would make it worse.
    It all depends on if your chip is a good clocker, if it takes close to 1.5 to get to 5ghz and then your going up to say 1.53 with vdroop. I don't know if it was the heat or the voltage on at least 1 but seen 2 die and the replacement on this rig sits at 4.6
    Both systems used a hyper 212 and probably hit close to 70c fully loaded I will say both systems were not kept up with the dust so that could of led to a creep in the temperature.
    I think one chip died due to a glitch in the bios when it was switched from offset to manual voltage or vice versa because after that it never booted.
    Xtreme Mentor
    Apr 2003
    Ankara Turkey
    I was able to run my 3770k @4.6 for more then 3 - 3.5 years but after that i needed to decrease clock step by step. Before I changed it this black friday it decreased to 4ghz.
    When i'm being paid i always do my job through.
    Jun 2005
    2600k since 2011 @ 4.8 ghz (1.42v) under water max load 65c , was stable and remain stable .
    2600K working in 4.8 GHZ so far
    2600k @(4600 Ghz) 1.42v : (under water)
    Asus B2 mobo
    4 GiG DDR 2400 MHZ
    GTX 570 @ 1.063v ( 910/1820/2001 Mhz) .(under water).
    1020 W PSU
    Hobie's : Overclocking .... Overclocking .... Overclocking
    Jun 2007
    seems positive feed back. Actually wanted more input about sandy/Ivy bridge-E 6 cores cpus.
    but here is thing. I have tested few 3930k and 4930k. after few years of heavy overclocked chip stable at locked vcore, but when pass all stress test all of sudden during web browsing or light load it get just locked or refuse to run at that frequency and vcore.
    so more vcore needed is the sign of degration.
    [FSB<>BCLK]
    Oct 2002
    Front of computer
    I ran a 3770K @ 5Ghz /1.5v for a little over 2 years, and now 4.8 Ghz /1.2v up until now(nearly 2.5 yrs) without a hitch whatsoever. In fact, and oddly enough, it's almost as though the chip voltage requirements actually improved over time. ie, the chip now seems completely stable in prime(large FFT's over 12hrs) with less voltage than was required in the beginning.
    3770K (delidded) - full nickel waterblock - liquid metal compound w/120.3 rad
    PS. I ran this chip at 5Ghz 1.48v for approximately 2 yrs, and decided to scale back to 4.8Ghz to keep temps under 75c during rendering. Whereas the 5Ghz setup would sometimes exceed 85c - hope this helps
    Step aside, and you won't have to feel the awesome wrath of my mustache!
