Results 1 to 3 of 3
Thread: AM4 bent pins on CPU
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    Today some more relax post, without benchmarks
    Last weekend I did overlcl:ing part at local gaming event. Of course, my choice were Ryzens (1800X and 1700X). At the end of event, at Sunday (horrible to know it is day of sun) I started with drying, unmounting and cleaning the processor. Ussually not many guys are cleaning side parts of IHS. But I do it . I took the chip in to the my hand and...booom, CPU felt on ground Some pins were bent.
    I have experience with straightening pins at Phenoms II. But there was it more easy. Pins there more stronger and size of gap also was bigger. So I had credit card and micropencil to fix it.
    But AM4 CPU has1331 pins and thats much more while also in the middle is empty part (square), so density of pins is higher. Much higher.
    I have CPU incident at two areas. One area only a little bent pins and second area with more numbers of bent pins and also smaller area with bent pins against each other pins.
    In the smaller are with hardest damage I could not use thight plastic card and micropencil.
    I used another smooth kit
    magnifying glass, small light, tight "white" plastic card and compasses (you can a needle).
    Sometimes I tried, if pins are straight and if CPU put in socket or not. I had to straighten the pins few times and afterall the CPU put OK to the socket.
    At the end I tried CPU in motherboard, if everything wrking. First bot, few test and I was happy CPU is alive
    ROG Power PCs - Intel and AMD
    CPUs:i7-6950X, i7-5960X, 4x i7-7700K, i3-7350K, 2x i7-6700K, i5-6600K, R7-1800X, R7-1700X, 3x AMD FX-9590, 1x AMD FX-9370, 4x AMD FX-8350,1x AMD FX-8320,1x AMD FX-8300, 2x AMD FX-6300,2x AMD FX-4300, 3x AMD FX-8150, 2x AMD FX-8120 125 and 95W, AMD X2 555 BE, AMD x4 965 BE C2 and C3, AMD X4 970 BE, AMD x4 975 BE, AMD x4 980 BE, AMD X6 1090T BE, AMD X6 1100T BE, A10-7870K, Athlon 845, Athlon 860K,AMD A10-7850K, AMD A10-6800K, A8-6600K, 2x AMD A10-5800K, AMD A10-5600K, AMD A8-3850, AMD A8-3870K, 2x AMD A64 3000+, AMD 64+ X2 4600+ EE, Intel i7-980X, Intel i7-2600K, Intel i7-3770K,2x i7-4770K, Intel i7-3930KAMD Cinebench R10 challenge AMD Cinebench R15 thread Intel Cinebench R15 thread
    Xtreme Cruncher
    Apr 2008
    Ohio
    I've been there, so far been lucky to get them back in line and CPU works again. Glad it worked out for you!
    AMD Ryzen ThreadRipper 1950x 4.1ghz
    Asus Prime X399-A
    GSkill Flare-X 3200mhz, CAS14, 16GB
    AMD RX Vega 56
    Xtreme 3D Team
    Jan 2009
    Ohio
    I have a 3x AM3 CPUs that were nearly destroyed about a year ago (20+ bent pins each) by a family member that broke / stole / sold a bunch of my stuff including my newer GPUs. Was using HD 5770 again all year until I bought a GTX 1060 recently.
    I will have to give these methods a try, they are really bad, some pins are bent all the way over flat.
    Smile
