Results 1 to 5 of 5
Thread: Loop order!!!
    Nov 2017
    Loop order!!!
    Hi girls an guys,
    My question is really simple, which loop will provide the best cooling performance? Here is the data and a picture.
    Components to be cooled:
    CPU (will be overclocked)
    Two GPU's (will be overclocked)
    Motherboard
    Loop components:
    All rads are 480 mm
    The pump is high performance
    All blocks are high flow certified, so no restriction
    Your help will be much appreciated.
    Attached Images Attached Images
    Jan 2010
    Houston, TX
    I would say either A or D, but ultimately the order has little effect on the performance of your loop. Flow rate has more of an effect on how well your loop cools than the order of your components. The water, or coolant, in your loop pretty much acts as a single entity.
    HAF 932-ASUS Rampage Formula III-i7 980x-12G G-Skill Sniper 1600 C9-GTX970 4g SLI-Corsair AX1200i PSU-Dual Loop WC
    Thermaltake W200-Rampage V Edition 10-i7-6850k-G-Skill TridentZ F4-3200C14Q-GTX1080Ti Strix SLI-Corsair AX1500i-Dual Loop WC
    Mar 2005
    I would go with whatever gives you the shortest loop without any tight bends
    provided flow rate is good order doesn't really matter as the water shouldn't heat up much more than 1c as it goes round the loop
    although if you wanted to run the pump at a lower rpm or the gpu were sucking 500w each with vmods then the water would probably get a bit hotter on the way round making the last component a bit hotter than it would be with rads between components
    so i would probably go c but without the vrm block on the mb restricting flow
    they may say high flow but they will all be adding there fair share of restriction
    TJ08-EW 6700k@4.7 1.375v - Z170-GENE - 2x8g 3866 16-16-16 - 1070@ 2088\9500MHz -Samsung 830 64G, Sandisk Ultra II 960G, WD Green 3tb - Seasonic XP1050 - Dell U2713 - Pioneer Todoroki 5.1 Apogee Drive II - EK VGA-HF Supreme - Phobia 200mm Rad - Silverstone AP181 Project Darkling
    3770k vs 6700k RAM Scaling, HT vs RAM, Arma III CPU vs RAM, Thief CPU vs RAM
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    A or D
    adding another pump an option?
    Intel 7960X ES @ 4.4Ghz
    ASUS Rampage VI Extreme
    GTX 1080ti Galax Hall of Fame
    32GB Galax Hall of Fame
    Intel Optane
    Platimax 1350W
    Enermax 240 Liqtech AIO
    Intel 8700K @ 5.2Ghz
    Asus Maximus X Apex
    GRX 1080ti Galax Hall of Fame
    16GB Galax Hall of Fame
    Intel Optane
    Platimax 1350W
