-100C Club Member
air conditioner project
hi i bought this secondhand air conditioner the other day and i need some help identifying it please
R22Chage 495g (is this how much oil it takes)
cooling:1750 PS660w
model KC05MG
ALSO on the inside the compresser had this information on it
80656545
C-IR57H5G SCS
10034
V220 230 240
H250 PH1
SIDE part no KR5279
serial No 0394 10414
code 80656545
any help or information would be great
ps sorry to say some of the numbers could be letters, and letters number it was very hard to read sorry
-100C Club Member
after pulling it apart i fired it up to make some ice
-100C Club Member
i stuck it in a container of tape water to have a quick look how it performs
it took 45 minutes to get the h20 down to 5deg
it was 30deg in the shed (little hot in there)
-100C Club Member
here you can see some ice forming around the evaporator
-100C Club Member
the dimensions of the evaporator are 24cm high and 38cm long.
the condensor is 44cm long and 33cm high.
next think i have to do is find an eski that i can fit that evaporator in. i think i will get one of those desk fans and make a shroud for it as with the original fan its a little loud and place it on the condensor to cool it down as it does get hot running without the fan. (like 63db of noise), with out the fan it sounds like a fridge (alot better)
-100C Club Member
well the system is almost up, just got to insulate the maze4 block for the gpu (top side of block) and i can start to oc, at the moment im getting a small pudle of water from the condensation.
i ran the air conditioner for one hour to pull the temperature of 20m liters of nulon coolant down to 0deg. then shut it off.
just sitting there it took 5 hours before it rose to 1deg in the eski. i ran the sytem for 2 hours cooling the peltier and the coolant rose to 10deg. i then ran the airconditioner for 15 mins and it brought it back to zero.
i cooled the water to 0 deg then the very next day it had one rose to 15degs.
-100C Club Member
not sure on the horse power yet most probly 1/2 or 3/4
So what do you wanna know?
-100C Club Member
it has 1750w heat removal
i guess i would like to know the BTU and what size compressor it is
just curious why would you want to run your chiller in this manner?
-100C Club Member
cause i dont have anti freeze.
today i switched to nulon anti freeze to chill down to -20deg in 2.5hours
i insulate the graphics card block because it has condensation forming on the back
- You may not post replies
- You may not edit your posts
Forum Rules
