Results 1 to 2 of 2
Thread: TR 1950x DDR4 kits
    Sep 2008
    TR 1950x DDR4 kits
    I recently switch from 6700k to TR 1950x. Im using Corsair DDR4-3200 kits temporary from my 6700k system. Im pretty lost on how to get DDR4 3200 stable. Not sure if the soc voltage is similar to vccio on Intel. Also what is the good quad channel kits? Like DDR4-3600 or slightly lower. I was trying to push higher memory frequency.
    TR 1950x
    8GB x 2 DDR4-3200 16-18-18-36 v1.3
    Samsung 950 Pro 256GB
    MSI X399 Gaming Pro Carbon
    GTX 1080 ti
    Phenom II X6 1055T @ 3.5/2.5NB/2 GHz | SST 2x2GB DDR3-2200CL8 @ 1666 6-6-6-18-1T | Biostar TA890FXE | Diamond HD3870 | Seagate 1 TB 7200.12 | Corsair TX750
    Oct 2005
    I would get the G.Skill Samsung B-Die kits.
    The 3200 cas 14 Trident Z and the 3600 Cas 16 kit should both be Samsung B-Die.
    I have the 3200 Cas 14 Trident Z RGB kit and it runs 64gb(16*4) at 3200 CAS 14
