Results 1 to 6 of 6
Thread: Looking for help and advice
    Jul 2017
    Hi all, I'm new to the forum and looking for advice on building a pc, I mainly play Farming simulator Euro Truck simulator but would like the pc to be more than capable of playing those sort of games and also stuff that's more taxing, my budget is around ?1000.
    So any help or advice on a decent spec for that budget would be much appreciated.
    Thanks Mat.
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    In that budget for an entire pc and those requirements i would say APU is your only option without sacrificing quality where it matters (power supply).
    I would postpone for ryzen APU product launches if it was me.
    heatware chew*
    I've got no strings to hold me down.
    To make me fret, or make me frown.
    I had strings but now I'm free.
    There are no strings on me
    Xtreme Cruncher
    Apr 2008
    Ohio
    The RX 560 is a decent gaming card and is around 130. It also requires no extra power connections if you pick the right one, and can run on 400watt PSU no issues. My son has an AMD system built around that GPU, and it all cost under 1000. The below cost about $640 and leaves room for your choice of Case and Hard drive. My son has the Samsung EVO 500GB SSD which he already owned. The drive is $186 right now. which still keeps you under 1000.
    RX 560 AERO ITX 4G OC
    AMD Ryzen 3 1300x
    G-Skill Flare-X 16GB (2x8) 3200mhz
    MSI Tomahawk B350
    Corsair VS500 - 500w
    Windows 10 Home
    ~1~
    AMD Ryzen 9 3900X
    GigaByte X570 AORUS LITE
    Trident-Z 3200 CL14 16GB
    AMD Radeon VII
    ~2~
    AMD Ryzen ThreadRipper 2950x
    Asus Prime X399-A
    GSkill Flare-X 3200mhz, CAS14, 64GB
    AMD RX 5700 XT
    Jul 2017
    Sorry my budget is around ?1000 Not dollars sorry for the confusion.
    Xtreme Enthusiast Shocker003's Avatar
    Jul 2007
    Germany
    Quote Originally Posted by matstrooper View Post
    ?1000 please what is ?(euro or pound)
    MAIN RIG--:
    ASUS ROG Strix XG32VQ---:AMD Ryzen 7 5800X--Aquacomputer Cuplex Kryos NEXT--:ASUS Crosshair VIII HERO---
    32GB G-Skill AEGIS F4-3000C16S-8GISB --:MSI RADEON RX 6900 XT---:X-Fi Titanium HD modded
    Inter-Tech Coba Nitrox Nobility CN-800 NS 800W 80+ Silver--:Cyborg RAT 8--:Creative Sound BlasterX Vanguard K08
    Jul 2017
    Sorry it's pounds just realised it won't put a pound sign
