Acer is releasing the Z35P Monitor with a native 3440x1440 resolution it can manage 120 Hz refres rates and is a G-Sync screen. The display is based on a 35? AMVA (Advanced Multi-Domain Vertical Alignment) panel.
The curved display offers a 3440 x 1440 resolution (21:9 UltraWide aspect ratio) with 2800R curve. The panel actually is a 100Hz refresh rate one, but Acer does some internal overclocking and made that 120Hz. G-SYNC has a variable refresh rate range of 30 ? 120Hz. ULMB (Ultra Low Motion Blur) is not supported due to the backlight of the panel itself not supporting this modulation method.
The monitor offers 8-bit colour reproduction and is tagged with a 2500:1 static contrast ratio is specified alongside 178?/178? viewing angles and a 4ms grey to grey response time. Brightness output is 300 cd/m? maximum. It has a 100 x 100mm VESA mount and display outputs include DP 1.2 (supports G-SYNC), HDMI 1.4 and 4 USB 3.0 ports (plus upstream). 2 x 9W DTS speakers with ?Acer True Harmony? are also included for potentially quite decent sound output.
The monitor is available in the US for a rather steep $1100
