The T6 computer case with a contemporary and all meshed front panel, based on the 0.5mm SGCC ATX chassis structure. The contemporary front panel is minimalistic and functional with USB2.0 | 3.0 and HD Audio on the top for easy reach. This well-designed tower structure provides sufficient space for hardware installation and component cooling. The chassis structure is prepared for adequate cooling, we have pre-assembled 1*120mm blue LED cooling fan in the front of the chassis and there is further space for another 1*120mm cooling on the front, 1* 120mm cooling fan on the rear and 2* 120mm fan on the side panel for additional VGA card and GPU cooling.
The internal space design is well thought out and supports a full drive bay rack for the installation of three drive bays 3.5 inch and two drive bays 5.25 inch, additionally you can mount two SDD drives 2.5 inch. There is room for the expansion of upgrade cards up to six units. Looking for a companion on one of your many computing adventures, well the luck is in your favor with the T6 ATX powerhouse which will help you lead to victory.
