Results 1 to 8 of 8
Thread: Need help folks
    Mar 2010
    Minnesota
    Need help folks
    Other thread was on the 390. Got it back (refurbed). Tried installing with updated drivers from amd for the 390. WoT will not play as well as iTunes says no video playback. Tried going back to the 795 with drivers for that, Nope, same crap. GPU-Z sees it. Can run cinebench too. Its like I am missing something as it thinks i have an old gpu (according to itunes). Downloaded latest drivers from AMD. Am thinking the refurb card did something but with gpu-z seeing it and cinebench, don't know. Suggestions?
    Xtreme Cruncher
    Nov 2008
    NE Ohio, USA
    Have you cleaned all the drivers out with something like Driver Sweeper, then re-installing newest drivers for that card? I had an issue where an old driver file was still hanging around and screwing with my GPU not being recognized by BOINC. Just a thought.
    24/7 Cruncher #1
    Crosshair VII Hero, Ryzen 3900X, 4.0 GHz @ 1.225v, Fractal Design Celcius S36 AIO, 4x8GB GSKILL 3600MHz C15, 2x MSI 1660ti Armor OC
    Samsung 970 EVO 250GB NVMe, 2x10TB WD Red RAID1, BR Burner, Win 10 Pro, Enthoo Luxe TG, SeaSonic Focus+ Platinum 850W
    24/7 Cruncher #2
    GA-P67A-UD4-B3 BIOS F8 mod, 2600k (L051B138) @ 4.5 GHz, 1.260v full load, Arctic Liquid 120, (Boots Win7 @ 5.6 GHz per Massman binning)
    Samsung Green 2x4GB @2133 C10, 2x MSI 1660ti, Vertex 4 128GB, 2x3TB WD Red RAID1, BR Burner, Win7 Ult x64, Enthoo Pro, HX750
    24/7 Cruncher #3 ... Crucial M225 64GB SSD Donated to Endurance Testing (Died at 968 TB of writes...no that is not a typo!)
    GA-EP45T-UD3LR BIOS F10 modded, Q6600 G0 VID 1.212 (L731B536), 3.6 GHz 9x400 @ 1.312v full load, Zerotherm Zen FZ120
    OCZ 2x2GB DDR3-1600MHz C7, Gigabyte 7950 @1200/1250, Crucial MX100 128GB, 2x1TB WD Red RAID1, Win7 Ent x64, Centurion 590, XFX PRO650W
    Music System
    SB Server->SB Touch w/Android Tablet as a remote->S/PDIF->Denon AVR-X3300W->JBL Studio Series Floorstanding Speakers
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Try installing the OS with the 390 installed, if you have a spare HD. It will confirm if the vga is damaged.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Mar 2010
    Minnesota
    Have guru driver remover so do remove the drivers. When I try to load WoT, it tries to kick in then disappears. Dam 7950 was working great until I tried the swap. Found my original install disc from sapphire so will remove the drivers, then try this. Thought maybe the APU wasn't pumping enough juice but it runs cinebench fine. Any other program out there to stress the gpu that won't work if there is issues? Not ready to reinstall the OS until next week after step daughter wedding this weekend. Hoping I don't have to go that far.
    Xtreme Cruncher
    Nov 2008
    NE Ohio, USA
    There's a Render Test in GPU-Z. There's a "?" to the right of the Bus Interface field on the GPU-Z screen. Click on the "?" to bring up the Render test screen. It's not a full load test, but may tell you something???
    24/7 Cruncher #1
    24/7 Cruncher #2
    Music System
    Mar 2010
    Minnesota
    Thanks for the tip. You folks won't believe this. I put the 390 in after removing drivers. Used the install cd that came with it. Has the catalyst control center that i think amd changed. Ran the gpu-z render first. Ran fine. Almost maxed out the card. Fired up WoT. It works now. May be a bunch of updates behind on the amd drivers but its working and not going to update. Thanks for your help guys.
    Xtreme Cruncher
    Nov 2008
    NE Ohio, USA
    What driver version? Yeah, I don't like that change they made you're talking about myself. Didn't that start when Crimson Edition came out?
    Glad you got something working!
    24/7 Cruncher #1
    24/7 Cruncher #2
    Music System
    Mar 2010
    Minnesota
    The card is working out ok but man this thing could heat a house. Wondering if updating the software would help or make it worst. Not sure what version I am on as I'm not home now. Will check and post.
